Awesome, that's great! It helps because sometimes the springs get weak too.
Now you should log again, and then set your static map to the values you see that stabilize the boost. After that you won't get any spikes!
BTW, I just did the calculations for the VNT15, aka 1749va turbo, and you can go higher on boost.
It's nice to see that yes, it can do 20-21 psi, but only at a certain range! (and of course to limit spikes!) I am reminded of a few people that did exactly that, 21 or so psi! Even my old vnt15 did 24 psi spikes with no probs. I upgraded when they had vnt17 cheap on ebay lol.
It explains what causes them to blow up (surge esp at altitude - not really choke), and they seem to be even less affected in high rpm than the VNT17, I suppose because they share the same housing, so it is flow limited (which pushes the right line- aka choke line).
Also, this map and the VNT17 map makes me see why people get dynos where the HP becomes flat, the boost drops, so less mg/s at higher rpm, BUT higher rpm makes up for the loss in torque (same hp). At higher altitudes the HP curve looks more like a gasser at sea level (thanks for turbos!).
If you want to use these values (or a percentage of them), use the absMBAR ones, in the boost limit map (redo the rpm axis to cover all rpm), and for the in between altitudes ex in vagsuite: hold shift select 1500rpm for 1000 and 1500rpm for 850, then right click smooth.
The 1000mbar values go in the normal boost map.
I was wondering when we'd get a pro in here
haha. REMEMBER THE TITLE OF THE THREAD.
Rob, took your advice and set the actuator to crack at 5 psi (or maybe a bit over). Now I can make it overboost to about 18.5 psi, which isn't much over the 2200 mbar I've got in my boost map. Much better than the 22 psi I would sometimes see (and then immediately let off the gas, lol).
Kerma, I was thinking that if I didn't touch the N75 upper limiter it would allow it to fully open during the initial rise, and then back off so that it wouldn't overshoot (if the PID were tuned correctly). Of course, we're talking differences of a fraction of a second to come to full boost from no boost which is not really something I care about in a daily driver. Anyway, I did (I think) try to change the N75 limiter to get that effect - I probably didn't do it right - and messing with the actuator worked perfectly.
