sfoote
Since early in my TDI's life I have had "shuddering" occur intermittently while idleing, usually after slowing down at a stop light or stop sign.
Now this is a daily issue, some days it is light, others it feels like I am only firing on three instead of four. Flippin' pisses me off.
About three months ago I had a CEL for a bad glow plug and low power symptoms. Dealer replaced glow plug and car seemed to run better, started better for sure.
I have noticed that the shudder is usually worse in Albuquerque, NM than in Las Cruces, NM where the elevation difference is several thousand feet higher in Albuquerque.
I think I am going to fiddle with the MAF tomorrow as I have read here that that may be the cause of the shudder.
This morning while changing my oil I noticed that rear of my engine, beneath the turbo, is covered with a lot of residue on the block, on several hoses, and all over the actuator which is wrapped in a reflective insulation blanket with button snaps holding it around the actuator. At first I thought it was a small oil leak as I saw some residue on the cross member just rearward of the oil pan, but then I started looking closer and it looks like I am getting exhaust blow-by from somewhere.
I make long high-speed trips (3.5 hrs at 85-90mph straight, no stops, no slowing down) so I don't think I would have a plugged egr, but why am I getting all of this sooty, oily residue behind my engine???? I have owned 5 diesel trucks and never saw anything like this.
Stats:
54000 miles on unit
42-44mpg @80-90mph
Blackstone labs reports no unusual wear
Comments?
Stats:
54000 miles on unit
42-44mpg @80-90mph
Comments?
