Pull the booster vacuum tube off, the back seal of the master cylinder may be bad, and it is being drawn into the booster, and will eventually get sucked into the engine's intake manifold.
You may have to take a long piece of something and snake it into the booster hole towards the bottom to see if it is wet, since the hole is halfway up the side.
