Sorry I can’t be of help here, but I am running larger Audi brakes and rotors on the B4V and they are so much better than the stock ones. It has ABS but if it’s any indication, the larger brakes definitely make a difference.
Thanks Mark, glad to hear about your upgrades. I have several questions about this I will just post them out and you can respond when you have time. If I've left out something relevant please just bring it up!
1) Is the Audi upgrade front and rear?
2) Is this 4x100 or 5x100 setup?
3) What are the specs for the rotor upgrade? Is the front bigger than the 280mm Corrado (assuming 4x100)?
4) Do you have part numbers for the upgrade or know what vehicles they're sourced from?
What’s the 1” mc off of, and is it a direct bolt on... even hard lines?
-Todd
The 1" MC is a direct fit item that was used on some Audi cars 1989-92 100/200 quattro and some coupes w/o ABS. It's identical in dimensions to the 22mm MC on the non-ABS Mk3 and B3/4 cars. It requires no changes to fit, even hard lines.
I'm now debating fitting one to the B3V next time the braking system gets serviced. I haven't looked at it recently but it has 38k miles on it since it came out of the shop in 2016, the fluid will need to be flushed on this next summer, same with the Mk3 Jetta that got a new MC in 2014.
Kind of planning ahead actually.
Audi part number 441611021A
Wagner MC128222
Raybestos MC390058
Cardone 112807 (reman)
Centric 130.33110
Steve
