Cha2ga
2000 New Beetle, ALH, 5 speed.
Gentlemen I'm not very proud of myself at this moment. As a experienced Marine Corps helicopter mechanic and then receiving an industrial maintenance degree and working in industry as a maintenance and engineering technician for more than 20 years, all I can say is I screwed up. I was using a calibrated torque wrench. Unfortunately it doesn't help if the torque setting is the wrong one! I snapped off the bolt of the #2 injector hold down clamp inside of the head. I had the torque wrench set to 30ft-lbs. It never got close to 30ft-lbs, it was turning very easily but obviously snapped. I have sprayed Sili-Kroil into the top of the broken bolt and allowed it to sit. When I push on the sides of the bolt with a jewelers tip screwdriver, I can see the Kroil move around and the bolt looks like it is not tight in there, it appears to have some movement. I know I deserve the criticism; however, right now I would prefer your help. I'm thinking I need to use a left hand drill bit or an easy-out. Any help and suggestions to get me out of this bind are appreciated.
