Hasenwerk
Vendor , w/Business number
- Joined
- Nov 28, 2003
- Location
- Quesnel, BC
- TDI
- 1982 Cabriolet (BEW|VNT17|Stage4), 1989 VW TriStar Syncro soon-to-be CR TDI (CBEA), 2001 Ford Ranger Edge 4x4 (ALH|VNT17|R520|Stage4)
Haven't seen TDI Motorcycles discussed for a while here, so let's!
Available to me is an early 80s BMW R Series bike with a sidecar. Engine/transmission has exploded.
BMW has a drive shaft instead of a chain system. As others have done, take a Golf style transmission, welding the diff and run the drive shaft off the rear-facing CV. This concept of driving the rear wheel VERY simple, as no adapter plates and precision alignment is needed. It's just a factor of mounting the VW engine and transmission - now you see why the sidecar is needed as it will be a HEAVY bike.
The downfall to this idea is this is a very long setup for a motorcycle and there is no way it would physically fit a standard BMW or really any other frame. Also a 1900cc TDI is *way* overkill in the power department too.
The 1.2L three-cylinder TDI found in the Volkswagen Lupo comes to mid as a smaller engine. Does anyone have measurements of the 1.2L TDI and it's transmission? Yes there is the Smart 42 CDI out there.... bah!
