ratkc135
So I went to check the pressure in my spare...and found standing water in the trunk.
I did a bedliner in this area to cover up dings, some holes and thinking it would deaden some sound...as well as make it look better.
I noticed some moisture in the trunk when I first got the car in March. So I replaced the taillight gaskets and trunk gasket. Weird thing now is that the carpet wasn't wet. No carpet on the sides of the trunk is wet/moist either. So I have NO IDEA how this water is getting in!!!!
I didn't think about it...until this happened....to have a drain hole. So I drilled a very small hole in the lowest part of the trunk to (hopefully) not allow this much water to accumulate.
So now I'm trying to figure out how this water got in!!! Anyone seen this before?
https://drive.google.com/open?id=101bsumglJ4qbZxrWXaSt3Lh-gMFfIG1M
https://drive.google.com/open?id=1kzuxdBtk0GUVvNc6W5zhS-NZLJwjsrkE
