ryanjames170 - below is the dyno plot from my engine - signature copy for reference, but I don't have half of the things I recommended
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP110 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, GTC1444VZ, 3 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
I'd be surprised if you can duplicate this, or even close, without an ECU. If you do, there will be significant compromises made to achieve it. I've been through 3 different turbos, 3 sets of injectors, 6 tunes from 3 different tuners, two different injection pumps, 2 different cams at various degrees of advance/retard, etc and without a doubt, the modification with the most significant impact on everything you're looking for is the ECU/tune.
Not trying to rain on your parade here, but I think you're in for an uphill battle. The injection pump/nozzles and turbo are really the only variables that you have to play with, and if it's not what you want, they're difficult/expensive to change.
