Performance_Addict
To the Passat Guru's...
I have done the BSM fix, timing bbelt work done and had it chipped by Bora. Ever since the Bora reflash, this car has been throwing fault codes. Car didn't start today. Had to turn it off and then back on. Did that 3 times until it finally started. Check Engine light came back on. It has been off and on sporadically. The Mass air flow problem has come off an on. I always attributed future check engine lights to it. I know. Bad idea. So here are the new fault codes it threw today:
I am having a hard time believing the car has all these issues all of a sudden. Besides today, it starts, runs, accelerates, brakes and idles great. Gets 36MPG mixed driving, mostly freeway. Seems normal, right? However these new codes make me think something like the ECU might be bad or the programming might be. Opinions? Car has 76K. Any of this under warranty? I hate taking it to the stealership. : ( Feedback and education is greatly appreciated...
VAG-COM
Windows Based VAG/VAS Emulator
Version: Release 409.1-US
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Wednesday, 28 July 2010, 22:10:32
VIN Number: WVWAE63B55P018143 License Plate:
Mileage: Repair Order:
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,57,58,76
Address 01: Engine
Controller: 038 906 016 R
Component: R4 2,0L EDC G000AG 6416
Coding: 0150034
Shop #: WSC 66565
1 Fault Found:
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 000 - - - Intermittent
Readiness: N/A
Address 02: Auto Trans
Controller: 3B0 927 156 CF
Component: AG5 01V 2.0lPD USA 0404
Coding: 0000134
Shop #: WSC 00028
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 003 - Mechanical Failure - Intermittent
Address 03: ABS Brakes
Controller: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04257
Shop #: WSC 00028
2 Faults Found:
P1850 - 35-10 - - - Intermittent
Address 15: Airbags
Controller: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 00028
No fault code found.
VAG-COM
Self-Diagnosis Log
Page 2
Address 17: Instruments
Controller: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 15235
Shop #: WSC 00000
WVWAE63B55P018143 VWZ7Z0D0139188
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway
Controller: 6N0 909 901
Coding: 00006
Shop #: WSC 00028
1 Fault Found:
Address 46: Central Conv.
Controller: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0004
Coding: 00257
Shop #: WSC 02503
Address 56: Radio
Controller: 3B7 035 180 G
Component: Radio PM6 0016
Coding: 00031
Shop #: WSC 00028
End --------------------------------------------------------------------------------------------Windows Based VAG/VAS Emulator
www.Ross-Tech.com
Dealer/Shop Name:
Self-Diagnosis Log
Address 01: Engine
Coding: 0150034
Shop #: WSC 66565
1 Fault Found:
Readiness: N/A
Coding: 0000134
Shop #: WSC 00028
1 Fault Found:
Coding: 04257
Shop #: WSC 00028
2 Faults Found:
Address 15: Airbags
Coding: 12345
Shop #: WSC 00028
VAG-COM
Self-Diagnosis Log
Page 2
Coding: 15235
Shop #: WSC 00000
1 Fault Found:
Coding: 00006
Shop #: WSC 00028
1 Fault Found:
Coding: 00257
Shop #: WSC 02503
Address 56: Radio
Coding: 00031
Shop #: WSC 00028
