NewTDI,
Clean with contact cleaner first, and then just do your best to "Fill er Up". Remember what you want to do is displace any available air space in there with the dielectric grease. Basically filling it up will not allow any room for water, or vapor buildup. It also keeps air(oxygen) from between and surrounding the electrical connections that would otherside cause them to oxidize. Oxidation over time will cause the contact resistance to raise and could eventually cause the contact to fail. Spray and clean fuse and relay contacts one by one also. I have seen some get so bad that they have started fires in fuse panels before, specifically the fuse panel on top of the battery. This is very worthwhile preventative maintenance, and I know this has saved me quite a few headaches myself.
