Thinking about selling my Golf. Wanted to see what the offers would be.
2001 VW Golf that is the 2dr model- not easy to find a 2dr Golf. Tornado Red Located in Southern W VA
I've owned the car since 60k miles and have a list of mods done to it. The major negative is that I think the car had been wrecked since the paint on the front fenders and hood is starting to have a fade tint. And the airbag light is on - which is a common item for 2001 model year. Something about the wiring harness in the seat.
vnt17 turbo that has been ceramic coated by www.swaintech.com
3" FMIC and the intercooler pipes have been ceramic coated by HPC
pp764 injectors that were correctly installed by Greg - Lubespecialts
11mm pump
ECU tuned by rocketchip with stage 3 and stage 4 settings
2nd ECU that has a custom tune for less sprinted driving style and better MPG.
So between the 2 ECU's you have three tuning options.
.651 5th gear that was low friction coated by swaintech to squezze out even more MPG
pd130 intake that was polished then coated by HPC
largest passat TDI heat exchanger for quicker warmups and better oil temps
Fuel cooler
CAT2 fuel filter kit Installed when I bought the car at 60k to keep the fuel system extra clean
Shine racing springs The springs are not lowering springs. They keep the correct height and increase spring ratings.
Koni Yellow shocks adjustable Lifetime warrenty
Ebaich sway bars front and rear
Rieger rs4 front bumper Real rieger bumper not a cheap fiberglass knockoff
R32 real OEM rear bumper that was factory painted
5th brake light mod done with new OEM taillights Old tail lights were slightly faded
Hella Glass e-code lights with foglights with protective film
Stock 6 disc CD changer
15" stock rims with pair of snow tires with over 80% treadleft
16" ssr type C knockoff style rims with summer tires
Amsoil Oil bypass filter
timing belt tool set
complete stock injectors.
new MAF installed and a second spare new MAF
3bar Map
boost gauge
Spec stage 2 clutch
TDI sport badges
Battery relocated to the rear with a new gelcel battery
New rear dual exhaust with stainless steel tips
EDIT 090307
Now taking offers. I'd prefer to give a good deal to a tdiclub member that will value the car and be able to take care of it.
Located in Pikeville Ky
11mm pump
Fuel cooler
3bar Map
boost gauge
Spec stage 2 clutch
TDI sport badges
EDIT 090307
