Old June 20th, 2016, 18:26   #1
Conti
Default ALH from a Jetta into a NB convertible
I couldn't seem to find this exactly, firstly, can you use a Jetta engine harness in a new beetle? I did a Jetta vr6 to 1.8t swap using Jetta harness and I know you must cut and solder a bundle of wires for the washer fluid level and the pump Ect. But beetles have the engine computer in a different location than Jetta. Can you make it close enough to work?
I may get a deal on a 55k mile 04 beetle convertible 1.8t with a bad transmission, and I have a wrecked 02 Jetta tdi with only 100k and I was thinking beetle tdi convertible. I know I will need a new fuel tank and filler neck, possibly the lines, are the convertible fuel tanks the same as coupes? How about instrument cluster, just get one from an 02-03 diesel one? Anything else I'm missing? Thanks!
Conti is offline   Reply With Quote
Old June 20th, 2016, 19:07   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Technically that would not be legal. Because you cannot put an engine that is OLDER than the car in there, and there were no ALH powered 2004 vehicles sold new here.
There is also the issue of the CAN bus differences for 2004. The BEW's EDC16 system was designed to work with all the systems in the 2004 cars, the ALH's EDC15 system was not. So you may find you'd have to change a lot more than just the engine bits. The CCM, ABS, SRS, cluster, and possibly other bits would be incompatible as well.
So a BEW swap would certainly be easier.
oilhammer
www.cardocautomotive.com
Old June 21st, 2016, 19:55   #3
Conti
Well, I also have a 00 new beetle 1.8t with a seized engine and junk trans I was considering doing also. Would the harness thing still be an issue?
Old June 22nd, 2016, 04:13   #4
oilhammer
oilhammer's Avatar
It would be much easier on the 2000. You'll still have to swap over a bunch of stuff, but at least the other modules in the car will work fine with the ALH's ECU.
oilhammer
Old June 23rd, 2016, 06:07   #5
compu_85
Gadget Guy
compu_85's Avatar
Aren't both the 02 and the 04 cars CAN 1.6 though? Does the 04 have ESP?
-J
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
TDI Convertible NB Suggestion dieselfuel TDI Conversions 5 March 12th, 2010 16:07
Anyone have a NB TDI to Trade for BMW Convertible? BMWTDI TDI Cars for Sale/Wanted 1 August 14th, 2006 19:46
Convertible NB TDI Faceplant VW MKIV-A4 TDIs (VE and PD) 2 June 3rd, 2004 09:15
TDI NB Convertible? woodyRN VW MKIV-A4 TDIs (VE and PD) 4 March 27th, 2004 12:34
NB Convertible TDI? Blackstallion VW MKIV-A4 TDIs (VE and PD) 5 August 27th, 2000 11:59
Page generated in 0.13671 seconds with 11 queries
[Output: 71.93 Kb. compressed to 63.68 Kb. by saving 8.25 Kb. (11.47%)]
