Ookpic
I'll start by saying that I'll never be towing anything that weighs even close to what this trailer hitch would be "good" for. I will have exact measurements and a complete parts list including prices I paid in CAD. Please be careful if you decide to use this design.
I have a Draw-Tite hitch on my Jetta and it is ok but I have a very steep driveway and it is always scrapping on it when I back a trailer in especially if there is any tongue weight. I was inspired by many designs on here on the club and on FB that are basically a DIY version of the Bosal or Westfalia hitch.
Parts List...
2 - 2" x 2" x 1/4" x 17" long angle steel - This left 5" stick out from the rear of the car and 12" inserted into the rear floor frame rail.
1 - 2" x 3" x 3/16" x 39.5" long rectangular tube steel - This is slightly longer than the actual measurements which left a small amount of grinding to fit tight.
1 - Curt Bumper Hitch #19030 - This is a Class III 500/5000 lb Receiver.
2 - 1/4" x 8" round steel - Bent around a larger piece of 2" round stock in a vice with a hammer.
2 - 1/8" stainless plate - Cut to exact dimensions of license plate then later modified one piece to the outside with access hole and lower folded over chain rest and inside piece to allow to sandwich the plastic between.
1 - Complete rear bumper assembly purchased from wrecker.
1 - Roll Pan spring flip license plate holder.
Cost...
$21 - Steel
$25 - Bumper from wrecker
$61 - Receiver
$36 - Taillight wiring converter
$100 - Welding (This is obviously the friend price!)
$60 - Estimated cost of Ball and Hitch.
I will edit this post when I have a bit of time with descriptions if people are interested.
After removing the stock Bumper I was left with the 2 brackets and cushions. My plan was to harvest the brackets.
I used an 1/8" drill bit and drilled through a piece of cardboard into the cushion about in the centre of the label warning not to puncture.
When drilling through there is only a small burst out of white oily fluid and gas.
This is the result of drilling through the cushion.
I then used a band saw to remove the scrap cushion remains. To my surprise, as I started cutting through, there was still some residual gas that escaped.
After removing the tail lights and rear bumper cover to expose the rear floor rail horns.
I had a friend mill out an L shaped slot with the intention of pouring weld to angle iron support. After many attempts to get the measurements "just right", I decided that I may change the plan and go with square tubing as the frame rail ends and had the entire L shape opened up to a square hole.
This was first attempt at milling out the L shape.
I traced out my license plate with a grease pencil and carefully cut the opening in the rear bumper cover and mocked it up on the car.
Parts List...
Cost...
$21 - Steel
$61 - Receiver
