Old February 20th, 2017, 13:57   #31
TheRachermobile
No I had absolutely no problems starting before I brought my car to them
TheRachermobile is offline   Reply With Quote
Old February 20th, 2017, 14:02   #32
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Originally Posted by TheRachermobile View Post
Shop said they found a valve at the fuel filter allowing air in the system, they replaced the filter and sealing ring at valve. Apparently the car starts and runs fine now. I have not been out to it yet, I will see when I get done at work. Is this common enough to feel confident this was the starting issue? Or should I be ever concerned and still make the drive to have the timing checked?
You just never know.
There is a valve of sorts there, a thermostatic tee, seals with a double oring. The rings can leak and occasionally the tee can crack.
Hopefully it runs great now. If not I'd be concerned they got the basic timing FUBAR.
BobnOH is online now   Reply With Quote
Old February 20th, 2017, 15:48   #33
Vince Waldon
Vince Waldon's Avatar
...and it will have been disturbed while unhooking or moving the fuel lines to change the timing belt, so it's a *possible* explanation for sure.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Won't start after timing belt replacement secretofnims TDI 101 20 June 13th, 2008 21:36
wont start after timing belt replacement sjmilks TDI 101 13 April 20th, 2008 18:29
Timing Belt Replacement- Belt Pulley and Tensioner replacement not a Must? investmart VW MKIV-A4 TDIs (VE and PD) 17 March 24th, 2008 08:09
Water pump replacement without timing belt replacement Octavian VW MKIV-A4 TDIs (VE and PD) 7 August 6th, 2007 06:43
turbo replacement with timing belt replacement jsepton VW MKIV-A4 TDIs (VE and PD) 2 August 16th, 2004 10:29
Page generated in 0.12194 seconds with 11 queries
[Output: 60.74 Kb. compressed to 55.27 Kb. by saving 5.47 Kb. (9.00%)]
