Thanks for all the suggestions on fueling.
Maybe we can start with the simple stuff for this noob
Regarding general fueling issues: I may have fueling problems because of large pressure drops in the system. For example, if the fuel line is too small or clogged or the fuel filter is clogged. (to start)
-Or- perhaps the fuel line length/tank elevation is enough different from a stock Passat to cause problems.
Here is exactly what I did regarding fueling up to the IP:
Stock toyota tank, taken apart and thoroughly cleaned. Fuel pump removed and in its place a viton tube extending to near the tank bottom.
Stock toyota fuel lines, except for Viton flex sections.
Fuel filter: New spin-on diesel filter (see post 162)
Do any of these pieces sound like a problem?
Spulen: did you use the stock fuel lines or increase their size?
The clear lines in between the filter and the IP seem to indicate reasonable flow. When I was first starting the engine and there were bubbles, they moved through quickly. Now there is just a small one that seems to stay in the line.
I am currently reading Whitedog's post about the injection pump.
http://forums.tdiclub.com/showthread.php?t=238872
I may have an intelligent question later...
Two things that bother me about mine: Injector balance and the start of injection. Those #'s seem to be way out of spec.
