Old April 16th, 2009, 01:35   #76
Jaco
Fuel Economy: 5.3 / 4.8 / 4.1
Originally Posted by majesty78
It is an upgrade, but a sintered disk is kind of "digital" in operation, only full open or full closed...if used with standard pressure plate and flywheel, you should prefer to take a organic disc.
And keep in mind, that your tranny has limited capability for torque!
Greets, Alex
Thanks , yeah the tranny isn't all that great either. Unlike the 1.9 one ,imo.
2004 Polo 1.4 TDi - GT1749V ~chipped by Rub87~
Jaco is offline   Reply With Quote
Old May 29th, 2009, 09:56   #77
cuky
TDI(s): 1.4TDI
hello,
I have a 1.4tdi Lupo. I swappped a VNT17 turbo from a golf 130cp on my engine. I made all the necesary adjustments except one, i don't know how to wire the N75 valve. It will work if I plug the wire from the valve that controlled the wastegate on the old turbo? will the ecu recodnize it when I will make the remap?
Sorry for my bad english.
cuky is offline   Reply With Quote
Old May 30th, 2009, 02:41   #78
Rub87
It should work if you take the "black box" from a vnt car, and plug it in yours, if you load the software with vnt setting (probaly based on audi 1.4tdi 90hp version) then you cazn check with actuator diagnosis to see if it works..
Please post your results as I'm really curious about the spool with the turbo..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old August 15th, 2009, 11:44   #79
cuky
TDI(s): 1.4TDI
I've mounted the PD130 turbo at last. I remapped it, but there is a problem. The power is not as expected, the car is halt a second faster to 60 then before...I tried 4 different mapps but result was the same.
The car in the engine compartment is stock, unless the turbo.
What could it be the problem? I reckon the injector nozzles are too small and an upgrade with the PD130 injectors is necesary, but I'm not sure.
Old August 16th, 2009, 03:32   #80
Rub87
does it smoke? do you have a boost gauge? how much boost are you running? does it spool well? did you also change the vacuum lines and the "black box"?
does the clutch slip?
Old August 16th, 2009, 05:09   #81
cuky
TDI(s): 1.4TDI
No smoke, not even a little bit. I have a boost gauge, it reads about 1.4-1.5bar. I've changed them all, they work ok.
The clutch is pretty solid, it dosen't slip at all.
Old August 16th, 2009, 05:30   #82
im570rm
cuky you're that guy who came to me with a broken 131pd turbo?
Audi a6 avant 2.5 tdi quattro
EX Alfa romeo 156 sw 2.4 jtd with 2260vk water cooled
EX Seat Leon 1.9 TDI ASV
im570rm is offline   Reply With Quote
Old August 16th, 2009, 05:36   #83
K.I.T.T.
K.I.T.T.'s Avatar
TDI(s): N/A
Cuky, what else have you changed apart from the turbo? I'm also interested in a turbo swap on my PD75 Polo. Did you use the stock PD130 turbo/maniford and just cut the extra runner off? Got any pics?
Thanks,
Ash
PD injector differences (click)
K.I.T.T. is offline   Reply With Quote
Old August 16th, 2009, 05:53   #84
Rub87
if the stock clutch doesn't slip at 1.5 bar there's definatly something not going well, a new car with strong remap can slip the clutch without too much smoke
if if you have boost and no smoke and the power isn't there's it's not getting the fuel.. can you post some logs? channel 8 and 4 and 11
Old August 16th, 2009, 05:58   #85
cuky
TDI(s): 1.4TDI
Thanks,
Ash
yes, i used the stock PD130 turbo, cut one runner and it bolted right up, The only problem is with the exhaust, the PD130 turbo has a diferent socket then the stock PD75 turbo (3 bolts instead of 4). So you have to make a custom downpipe.
Here's a link with same pictures, it's kanes project, I have no pictures of mine
http://www.a2-freun.de/forum/showthread.php?t=31555
Old August 16th, 2009, 10:05   #86
K.I.T.T.
K.I.T.T.'s Avatar
TDI(s): N/A
Thanks for that link Do you know what he did to make the 6 speed gearbox fit? ie. Flywheel/clutch/driveshaft combo used? Finally, did you swap over the black vacuum unit? How did you go about getting the VNT to work? Kind regards, Ash
Old August 23rd, 2009, 02:40   #87
cuky
TDI(s): 1.4TDI
I made 2 logs, channel 4 and 8.
http://img9.imageshack.us/img9/20/61670543.jpg
http://img30.imageshack.us/img30/5483/99014047.jpg
Old August 23rd, 2009, 04:16   #88
turbo johan
turbo johan's Avatar
Try to find smoke limiter map
It has almost stock fueling!
You can get a lot more fuel out of these injectors!
Bit of homework to do
Johan
VW Golf 6 GTD 270 Hp & 490 Nm DSG
Lupo PD 280 hp & 500 Nm.
Fastest ET 13.1 sec 1/4 mile @ 178 km/h
turbo johan is offline   Reply With Quote
Old July 3rd, 2010, 03:14   #89
tdi-performance
TDI(s): 1.9 TDI ++
Hi there.
Can anyone attach the VCDS logs of blocks 001/004/008/011 of remaped 1.4 TDI AMF engine.
Thanks in advance.
TDI Performance
tdi-performance is offline   Reply With Quote
Old July 4th, 2010, 09:25   #90
TheoSweden
TheoSweden's Avatar
TDI(s): A3Q,A4Q
Originally Posted by tdi-performance View Post
Hi there.
Thanks in advance.
Hi. I found some old logs, but not sure if I have that enginecode. They probably dont look perfect, but the engine runs pretty good, totaly smokefree even now with 30deg.C outside.
011:
torsdag,23,Oktober,2008,16:21:58
045 906 019 BH,,1.4l R3 EDC 0000SG 5209,
,Grupp A:,'011,,,,Grupp B:, Stoppat,,,,Grupp C:, Stoppat
,,Engine speed,Specified MAP,Actual MAP,D.cycle MAP v.,,,,,,,,,,
,TIDS-, 2800...3200rpm,1650-2200 mbar,1650-2200 mbar,40-95%,TIDS-,,,,,TIDS-,,,,
Markering,MÄRKE, /min, mbar, mbar, %,MÄRKE,,,,,MÄRKE,,,,
,0.35,1323,999.6,1050.6,24.7,,,,,,,,,,
,0.72,1344,1387.2,1060.8,24.7,,,,,,,,,,
,1.12,1344,1397.4,1101.6,24.7,,,,,,,,,,
,1.51,1386,1417.8,1152.6,24.7,,,,,,,,,,
,1.90,1407,1448.4,1193.4,24.7,,,,,,,,,,
,2.30,1449,1479.0,1234.2,24.7,,,,,,,,,,
,2.69,1491,1509.6,1275.0,24.7,,,,,,,,,,
,3.08,1512,1550.4,1315.8,24.7,,,,,,,,,,
,3.48,1554,1591.2,1346.4,24.7,,,,,,,,,,
,3.88,1596,1642.2,1397.4,25.1,,,,,,,,,,
,4.27,1638,1683.0,1438.2,24.7,,,,,,,,,,
,4.66,1680,1734.0,1479.0,24.7,,,,,,,,,,
,5.06,1743,1785.0,1530.0,24.7,,,,,,,,,,
,5.45,1785,1825.8,1591.2,24.7,,,,,,,,,,
,5.84,1848,1887.0,1652.4,24.7,,,,,,,,,,
,6.24,1890,1958.4,1754.4,25.9,,,,,,,,,,
,6.63,1953,2019.6,1846.2,33.5,,,,,,,,,,
,7.03,2016,2091.0,1968.6,40.2,,,,,,,,,,
,7.42,2100,2131.8,2111.4,43.0,,,,,,,,,,
,7.81,2163,2172.6,2264.4,46.2,,,,,,,,,,
,8.20,2247,2213.4,2376.6,50.6,,,,,,,,,,
,8.59,2331,2254.2,2315.4,51.8,,,,,,,,,,
,8.98,2394,2284.8,2315.4,53.4,,,,,,,,,,
,9.37,2478,2295.0,2284.8,53.0,,,,,,,,,,
,9.74,2562,2295.0,2335.8,54.2,,,,,,,,,,
,10.13,2625,2295.0,2295.0,53.4,,,,,,,,,,
,10.51,2688,2295.0,2315.4,53.8,,,,,,,,,,
,10.90,2772,2295.0,2315.4,53.8,,,,,,,,,,
,11.28,2835,2295.0,2325.6,54.2,,,,,,,,,,
,11.67,2919,2295.0,2325.6,54.2,,,,,,,,,,
,12.05,2961,2295.0,2335.8,54.6,,,,,,,,,,
,12.43,3045,2295.0,2335.8,55.0,,,,,,,,,,
,12.81,3108,2284.8,2346.0,56.2,,,,,,,,,,
,13.19,3150,2284.8,2295.0,56.2,,,,,,,,,,
,13.56,3213,2274.6,2305.2,56.6,,,,,,,,,,
,13.94,3276,2274.6,2305.2,57.8,,,,,,,,,,
,14.32,3339,2264.4,2284.8,58.2,,,,,,,,,,
,14.69,3381,2264.4,2264.4,58.6,,,,,,,,,,
,15.07,3423,2254.2,2264.4,59.0,,,,,,,,,,
,15.45,3486,2244.0,2254.2,59.4,,,,,,,,,,
,15.81,3528,2244.0,2254.2,59.8,,,,,,,,,,
,16.19,3570,2233.8,2254.2,59.8,,,,,,,,,,
,16.56,3612,2233.8,2244.0,60.6,,,,,,,,,,
,16.96,3654,2233.8,2254.2,61.0,,,,,,,,,,
,17.36,3717,2223.6,2233.8,61.4,,,,,,,,,,
,17.75,3759,2223.6,2233.8,61.8,,,,,,,,,,
,18.15,3801,2223.6,2233.8,62.2,,,,,,,,,,
,18.54,3843,2203.2,2223.6,63.0,,,,,,,,,,
,18.93,3885,2182.8,2213.4,63.8,,,,,,,,,,
,19.32,3906,2152.2,2213.4,64.9,,,,,,,,,,
,19.72,3948,2131.8,2193.0,66.1,,,,,,,,,,
,20.11,3990,2101.2,2172.6,67.3,,,,,,,,,,
,20.51,4032,2070.6,2142.0,68.9,,,,,,,,,,
,20.90,4053,2070.6,2131.8,69.7,,,,,,,,,,
,21.28,4074,2070.6,2111.4,70.5,,,,,,,,,,
,21.67,4116,2070.6,2101.2,71.3,,,,,,,,,,
,22.07,4137,2070.6,2101.2,71.7,,,,,,,,,,
,22.47,4179,2070.6,2080.8,72.1,,,,,,,,,,
,22.87,4200,2070.6,2080.8,72.1,,,,,,,,,,
,23.27,4221,2070.6,2070.6,72.1,,,,,,,,,,
,23.66,4242,2070.6,2060.4,71.7,,,,,,,,,,
,24.05,4263,2070.6,2050.2,71.3,,,,,,,,,,
,24.44,4284,2070.6,2050.2,70.9,,,,,,,,,,
,24.82,4305,2070.6,2050.2,70.9,,,,,,,,,,
,25.21,4305,2070.6,2050.2,70.1,,,,,,,,,,
,25.59,4326,2070.6,2050.2,70.1,,,,,,,,,,
,25.98,4347,2070.6,2040.0,70.1,,,,,,,,,,
,26.36,4347,2070.6,2040.0,69.7,,,,,,,,,,
,26.74,4368,2070.6,2040.0,68.9,,,,,,,,,,
,27.12,4347,1611.6,2019.6,91.6,,,,,,,,,,
,27.51,4305,1224.0,1581.0,29.9,,,,,,,,,,
,27.89,4242,1224.0,1550.4,29.9,,,,,,,,,,
,28.27,4116,1224.0,1530.0,29.9,,,,,,,,,,
008:
torsdag,23,Oktober,2008,16:19:52
,Grupp A:,'008,,,,Grupp B:, Stoppat,,,,Grupp C:, Stoppat
,,RPM,Inspr.kvant.,Inspr.kvant.,Inspr.kvant.,,,,,, ,,,,
,TIDS-,,,,,TIDS-,,,,,TIDS-,,,,
Markering,MÄRKE, /min, mg/takt, mg/takt, mg/takt,MÄRKE,,,,,MÄRKE,,,,
,0.33,1365,42.5,37.3,32.4,,,,,,,,,,
,0.71,1386,45.0,38.4,33.2,,,,,,,,,,
,1.08,1428,70.0,39.8,33.8,,,,,,,,,,
,1.46,1470,70.0,40.6,34.6,,,,,,,,,,
,1.83,1491,70.0,41.7,35.4,,,,,,,,,,
,2.20,1533,70.0,42.8,36.2,,,,,,,,,,
,2.57,1575,70.0,43.9,36.8,,,,,,,,,,
,2.93,1617,70.0,45.0,37.6,,,,,,,,,,
,3.29,1659,70.0,46.1,38.2,,,,,,,,,,
,3.68,1701,70.0,47.2,39.0,,,,,,,,,,
,4.07,1743,70.0,48.6,40.6,,,,,,,,,,
,4.48,1806,70.0,50.0,42.5,,,,,,,,,,
,4.87,1848,70.0,50.8,45.0,,,,,,,,,,
,5.26,1911,70.0,51.9,47.5,,,,,,,,,,
,5.65,1974,70.0,53.0,50.0,,,,,,,,,,
,6.05,2037,70.0,53.8,52.2,,,,,,,,,,
,6.45,2121,70.0,54.4,55.5,,,,,,,,,,
,6.84,2184,70.0,54.6,59.8,,,,,,,,,,
,7.23,2268,70.0,55.5,59.8,,,,,,,,,,
,7.63,2352,70.0,56.5,59.8,,,,,,,,,,
,8.03,2436,70.0,57.4,59.8,,,,,,,,,,
,8.42,2520,70.0,57.9,59.8,,,,,,,,,,
,8.81,2604,70.0,58.2,59.8,,,,,,,,,,
,9.21,2667,70.0,58.5,59.8,,,,,,,,,,
,9.60,2730,70.0,58.5,59.8,,,,,,,,,,
,9.99,2814,70.0,58.7,59.8,,,,,,,,,,
,10.39,2898,70.0,58.7,59.8,,,,,,,,,,
,10.78,2982,70.0,58.7,59.8,,,,,,,,,,
,11.16,3045,70.0,58.5,59.8,,,,,,,,,,
,11.55,3108,70.0,58.5,59.8,,,,,,,,,,
,11.94,3171,70.0,58.5,59.8,,,,,,,,,,
,12.32,3255,69.7,57.9,59.8,,,,,,,,,,
,12.71,3318,69.5,57.4,59.8,,,,,,,,,,
,13.10,3360,69.2,56.8,59.8,,,,,,,,,,
,13.48,3423,69.2,56.5,59.8,,,,,,,,,,
,13.86,3465,68.9,56.3,59.8,,,,,,,,,,
,14.24,3528,68.6,56.3,59.8,,,,,,,,,,
,14.63,3591,68.6,56.0,59.8,,,,,,,,,,
,15.01,3633,68.4,56.0,59.8,,,,,,,,,,
,15.38,3675,68.1,55.5,59.8,,,,,,,,,,
,15.77,3738,68.1,55.2,59.8,,,,,,,,,,
,16.14,3780,67.8,54.9,59.8,,,,,,,,,,
,16.51,3822,67.8,54.6,59.8,,,,,,,,,,
,16.88,3864,67.5,54.4,59.0,,,,,,,,,,
,17.25,3906,67.5,54.1,58.5,,,,,,,,,,
,17.62,3948,67.3,53.8,57.9,,,,,,,,,,
,18.00,3990,67.3,53.5,57.1,,,,,,,,,,
,18.37,4011,67.0,53.5,55.7,,,,,,,,,,
,18.74,4032,67.0,53.0,54.4,,,,,,,,,,
,19.13,4074,67.0,52.4,53.5,,,,,,,,,,
,19.53,4116,66.7,51.6,53.3,,,,,,,,,,
,19.92,4137,66.7,51.1,53.0,,,,,,,,,,
,20.31,4158,66.7,50.5,52.4,,,,,,,,,,
,20.70,4200,66.7,49.7,52.2,,,,,,,,,,
,21.08,4221,66.4,48.6,51.6,,,,,,,,,,
,21.47,4242,66.4,47.5,51.3,,,,,,,,,,
,21.87,4263,66.4,46.4,51.3,,,,,,,,,,
,22.27,4284,66.2,45.8,51.1,,,,,,,,,,
,22.67,4305,66.2,45.0,50.8,,,,,,,,,,
,23.06,4326,66.2,43.9,50.5,,,,,,,,,,
,23.46,4347,66.2,43.1,50.5,,,,,,,,,,
,23.86,4368,66.2,42.5,50.5,,,,,,,,,,
,24.26,4368,66.2,41.7,50.5,,,,,,,,,,
,24.66,4410,65.9,41.2,50.5,,,,,,,,,,
,25.05,4410,65.9,40.6,50.2,,,,,,,,,,
,25.45,4431,65.9,40.1,50.2,,,,,,,,,,
,25.84,4431,65.9,39.5,50.0,,,,,,,,,,
,26.23,4452,55.7,39.0,50.2,,,,,,,,,,
,26.62,4452,45.6,38.7,50.2,,,,,,,,,,
,27.01,4431,0.0,39.0,36.2,,,,,,,,,,
,27.39,4347,0.0,42.8,33.5,,,,,,,,,,
,27.78,4326,0.0,44.7,33.2,,,,,,,,,,
004:
torsdag,23,Oktober,2008,16:13:48
,Grupp A:,'004,,,,Grupp B:, Stoppat,,,,Grupp C:, Stoppat
,,Engine speed,Specified start,Specified period,Cold Start Valve,,,,,,,,,,
,TIDS-,,,4..7*CA,3-80%,TIDS-,,,,,TIDS-,,,,
Markering,MÄRKE, /min, °BTDC,°KW,°KW,MÄRKE,,,,,MÄRKE,,,,
,0.01,1281,9.3,7.1,0.0,,,,,,,,,,
,0.40,1302,13.3,11.2,0.5,,,,,,,,,,
,0.80,1323,13.9,11.2,0.0,,,,,,,,,,
,1.19,1344,14.6,12.2,0.0,,,,,,,,,,
,1.59,1365,14.6,12.2,0.0,,,,,,,,,,
,1.98,1407,14.6,12.8,0.0,,,,,,,,,,
,2.37,1428,14.6,12.8,0.0,,,,,,,,,,
,2.76,1470,14.3,13.3,0.0,,,,,,,,,,
,3.15,1491,14.3,13.8,0.0,,,,,,,,,,
,3.55,1533,14.3,13.8,0.0,,,,,,,,,,
,3.93,1554,14.3,14.3,0.0,,,,,,,,,,
,4.32,1596,14.6,14.3,0.0,,,,,,,,,,
,4.72,1638,15.2,14.8,0.0,,,,,,,,,,
,5.10,1680,15.8,15.3,-0.5,,,,,,,,,,
,5.49,1722,16.1,15.8,-0.5,,,,,,,,,,
,5.88,1764,16.7,16.3,-1.1,,,,,,,,,,
,6.26,1806,16.7,17.3,-1.1,,,,,,,,,,
,6.63,1848,17.0,17.8,-0.5,,,,,,,,,,
,7.01,1911,17.4,18.9,-0.5,,,,,,,,,,
,7.39,1953,18.0,19.9,-1.1,,,,,,,,,,
,7.76,2016,18.0,20.9,-1.1,,,,,,,,,,
,8.14,2079,18.3,21.4,-1.1,,,,,,,,,,
,8.51,2142,18.3,22.4,-1.1,,,,,,,,,,
,8.89,2205,18.3,23.5,-0.5,,,,,,,,,,
,9.27,2268,18.6,24.0,-0.5,,,,,,,,,,
,9.64,2331,19.2,25.0,-0.5,,,,,,,,,,
,10.01,2415,19.5,26.0,-0.5,,,,,,,,,,
,10.38,2478,19.8,26.0,0.0,,,,,,,,,,
,10.75,2541,20.1,26.5,0.0,,,,,,,,,,
,11.12,2604,20.5,27.0,0.0,,,,,,,,,,
,11.50,2667,21.1,27.5,0.0,,,,,,,,,,
,11.88,2730,21.4,28.0,0.0,,,,,,,,,,
,12.28,2793,21.7,28.0,0.0,,,,,,,,,,
,12.67,2877,22.0,28.0,0.5,,,,,,,,,,
,13.07,2940,22.3,28.6,0.5,,,,,,,,,,
,13.47,3003,22.9,28.6,1.1,,,,,,,,,,
,13.84,3066,22.9,29.1,0.5,,,,,,,,,,
,14.24,3129,23.3,28.6,0.5,,,,,,,,,,
,14.64,3192,23.3,29.1,0.5,,,,,,,,,,
,15.04,3234,23.6,29.1,0.0,,,,,,,,,,
,15.43,3297,23.9,28.6,0.0,,,,,,,,,,
,15.83,3339,24.2,29.1,0.0,,,,,,,,,,
,16.23,3402,24.5,28.6,0.5,,,,,,,,,,
,16.62,3444,25.1,29.1,0.5,,,,,,,,,,
,17.02,3486,25.4,29.1,0.0,,,,,,,,,,
,17.41,3528,25.7,29.1,0.0,,,,,,,,,,
,17.78,3570,25.7,29.1,0.5,,,,,,,,,,
,18.18,3612,26.0,29.1,1.1,,,,,,,,,,
,18.57,3675,26.0,29.1,0.5,,,,,,,,,,
,18.96,3696,26.0,29.1,0.0,,,,,,,,,,
,19.34,3738,26.3,29.1,0.5,,,,,,,,,,
,19.73,3780,26.3,29.1,0.5,,,,,,,,,,
,20.11,3822,26.3,29.1,0.0,,,,,,,,,,
,20.51,3864,26.7,29.1,0.0,,,,,,,,,,
,20.88,3885,26.7,29.1,0.0,,,,,,,,,,
,21.26,3927,26.7,29.1,1.1,,,,,,,,,,
,21.66,3969,27.0,29.1,0.0,,,,,,,,,,
,22.04,3990,27.0,29.1,0.0,,,,,,,,,,
,22.41,4032,27.0,29.1,0.0,,,,,,,,,,
,22.78,4074,27.0,29.1,0.5,,,,,,,,,,
,23.16,4095,27.0,29.1,0.0,,,,,,,,,,
,23.54,4116,27.3,29.1,0.0,,,,,,,,,,
,23.92,4137,27.3,28.6,0.0,,,,,,,,,,
,24.30,4179,27.3,28.6,0.0,,,,,,,,,,
,24.68,4200,27.3,28.6,0.0,,,,,,,,,,
,25.06,4221,27.3,28.0,0.0,,,,,,,,,,
,25.43,4242,27.0,28.0,0.0,,,,,,,,,,
,25.80,4263,27.0,27.5,0.0,,,,,,,,,,
,26.18,4284,27.0,27.5,0.0,,,,,,,,,,
,26.56,4305,27.0,27.0,0.0,,,,,,,,,,
,26.92,4305,27.0,27.0,0.0,,,,,,,,,,
,27.31,4326,27.0,26.5,0.0,,,,,,,,,,
,27.70,4347,27.0,26.5,0.0,,,,,,,,,,
,28.09,4242,13.0,-1.5,0.0,,,,,,,,,,
,28.49,4284,13.0,-3.6,-1.1,,,,,,,,,,
That is all I found, hope it can help you.
//Theo
TDI Project: VW Golf 1 - 83
Track/Ice racer: Audi A3 TDI Q - 02 ~280hp
Daily driver: Audi A4 TDI Q - 08 ~300hp
http://65.110.12.166/showthread.php?t=378371
TheoSweden is offline   Reply With Quote
Page generated in 0.15196 seconds with 10 queries
[Output: 135.71 Kb. compressed to 114.37 Kb. by saving 21.35 Kb. (15.73%)]
