Old February 10th, 2020, 06:52   #1
300D
Default Quality Pre-painted fenders?
Anyone have any luck with the online pre-painted fenders? Which companies have people tried? My doglegs on both sides are pretty well perforated. I have done the clean-out and por-15 and paint and and, but really it's a losing battle. Rest of the car is actually pretty great considering coastal New England.
300D is offline   Reply With Quote
Old February 10th, 2020, 07:10   #2
oilhammer's Avatar
Fuel Economy: fantastic
I think it often depends on the color. Some are easier to match than others.
We sometimes get prepainted bumper covers here, they are usually decent but know that the aftermarket VAG fenders absolutely suck for fit and finish, and rust away quickly.
www.cardocautomotive.com
Old February 10th, 2020, 07:16   #3
300D
Good info. Thanks.
Old February 14th, 2020, 09:38   #4
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
I'm almost to this point myself. Whose fenders have you been looking at, 300D?
Right now I'm considering going with preprimed fenders and painting myself with Monstaliner in "Outbreak" - a very close match to Indigo Blue. Also would paint the hood at the same time. It's aftermarket and even though only 5 years old has collected a tremendous amount of paint chips. Frankly I like the look of the Jeeps that have done bedliner paint on the exteriors, and Monstaliner seems to have formulated their paints well (they don't use ground up tires for texture).
But if prepainted fenders are out there and of decent quality, I may go that route in the spring instead.
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old February 14th, 2020, 09:53   #5
KrashDH
TDI(s): 2002 Golf
My hood is at the point where it needs to be painted. A couple years ago I bough a DA buffer and went to town on the car thinking I was going to shine it up with some compound then wax. It looked so glossy when I was done with it!!
Unfortunately I must have buffed the last layer of the clearcoat off because the hood is oxidizing all over.
I think I am going to have the car painted. I'm looking into the Line-X Ultra line. It's made to paint entire vehicles and it's tough as nails.
Thinking about doing my truck at the same time. Never have to worry about rock chips, branches, or shotgun pellets again!
KrashDH is online now   Reply With Quote
Old February 14th, 2020, 17:37   #6
quartersaw
Fuel Economy: Passat:44mpg Golf 52MPG
I would buy the genuine article. It's easy enough to get matching paint. Here is a link:
https://parts.vw.com/a/Volkswagen_20...S/9277170.html
quartersaw is offline   Reply With Quote
Old February 14th, 2020, 19:39   #7
300D
Donít have a setup for a good paint job. I will cast about locally to see if I could install and someone else paint. OEMs arenít even that pricey.
Old February 15th, 2020, 19:36   #8
quartersaw
Don’t have a setup for a good paint job. I will cast about locally to see if I could install and someone else paint. OEMs aren’t even that pricey.
I bought OEM fenders for my 2002 Jetta wagon. I had the same problem as you do.
I bought a harbor freight paint gun, and used a crappy 50 buck compressor to do the job. I took a paint sample to an automotive paint store, and got a good match. 1/2 pint of paint, and a gallon of lacquer thinner did the job with paint to spare. If you eliminate the clear coat, the job will be WAY easier..(I clear coated my fenders) I would paint the fenders before installing them. You will eliminate a TON of labor.
I also painted the inside of the fenders as well. The factory primer alone, will not hold up against the moisture that gets back there.
..Can't beat brand new OEM metal! :-)
Old February 15th, 2020, 20:00   #9
Andyinchville1
May be the long game BUT if you are patient , you can locate factory original fenders (factory quality) in the same color aged to perfection (same year so no paint color / age matching) in a junk yard.
Over the years I put together an entire front clip for my other car in case of another deer strike .... ;-)
2003 Jetta tdi wagon , 5 sp, 316k miles, 11 mm pump, DLC 520, Malone stage 1, P205 70 R 15 Ecopias on Avus rims, hammer mod
Andyinchville1 is offline   Reply With Quote
Old February 15th, 2020, 20:28   #10
Problem with prepainted fenders is they'll probably look like the color doesn't match unless you blend them into the surrounding panels. I've had the front clip on IBW re-painted twice, and the hood a third time (failed clear bra install). Dark blue is easier to match, silver is hard.
I had fenders replaced as part of the rust warranty 5 years ago. Factory fenders, and they're starting to rust. This spring I'm having them either repaired or replaced, depending on what the body shop says will last longest. Hoping this is the last time.
2002 Jetta wagon, 407K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old February 16th, 2020, 15:40   #11
300D
Just as an added data point to this discussion, I looked up the OEM fenders online.
www.1stvwparts.com
www.expressoemparts.com
Both sites have them around $150 a fender. Wow, I thought, that's a nice price.
Then went to the shipping page. $450 and $550 for shipping. Good lord. Are they having someone individually drive it to your address? I don't think I have seen a shipping cost that high anywhere outside of a whole car.
Old February 16th, 2020, 21:03   #12
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
If you take to the local body painter to see what a cash job is it may not be so bad. Black is the cheapest common color out there according to the guy who painted my golf. Otherwise he said cash $100 each front body part (bumper, fenders) other then hood would be $200. He did my fenders 100 each and a black gti for 450 was the rest of the donation parts. Ebay fenders primed for close to 50 each shipped.
Sent from my SM-G950U using Tapatalk
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old February 17th, 2020, 10:27   #13
PickensSC
I used two of these from Amazon. I know everyone hates Amazon and the quarter panel might be thinner, but $60 delivered is a great price.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You can also get Harpy rattle can matched paint and clear coat for $40.
I bought a sprayer, link below, that doesn't require an air compressor. It did a good job. I went to my local auto paint store and picked up the paint and clear coat.
PickensSC is offline   Reply With Quote
Old February 17th, 2020, 19:31   #14
quartersaw
www.1stvwparts.com
I paid $169.00 each for the pair of genuine VW fenders, delivered. I'd call a dealer, and see if they can match that $210 pricetag-minus shipping
Old February 18th, 2020, 07:05   #15
Hwycruiser
Hwycruiser's Avatar
Fuel Economy: 43 mpg avg
I got a new primed front bumper cover off eBay from “newamauto” that was a good fit at a great price. I took it to my local body shop and had it painted. When I needed a front fender I shopped “car-part.com” to find a salvage car the same color as mine. It was easy to pull one off a donor car. The problem with the front end is that is where most of the damage occurs so it can be tough to find what you need. My car is black so its easy to match my color. There is a lot of vendors on eBay for the aftermarket, read their reviews.
2002 Golf GLS TDI manual, 2013 Passat SE TDI (rip-buyback)
2009 Jetta S 2.5, 2015 Jetta SE 1.8 TSI, 2016 Jetta S 1.4 TSI, 2017 Passat SE 1.8 TSI
Hwycruiser is offline   Reply With Quote
Are there factory painted fenders? blueapple VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 November 8th, 2012 19:58
New, OEM quality replacement fenders? 02PSDV8 TDI 101 4 September 6th, 2009 19:40
WTB Pre painted eyelids Golf MkIV 2005 HeAvYfUeL Upgrades (non TDI Engine related) 2 September 23rd, 2006 11:56
FS: MK5 Eyelids Pre-Painted $38.00 MK5EYELIDS.COM Private TDI Items for Sale/Wanted 3 June 28th, 2006 10:13
GB: PRE-PAINTED FK BADGELESS GRILLES $110 SHIPPED oldpoopie Vendor & GroupBuy items for sale 0 November 1st, 2003 00:45
Page generated in 0.17794 seconds with 12 queries
[Output: 132.30 Kb. compressed to 110.82 Kb. by saving 21.48 Kb. (16.23%)]
