Stephen P
If I hold a hard acceleration in 5th gear after about 8seconds the car will start to loose power and the CEL will turn on. Vag com shows Intake Manifold Pressure/Temperature.
Sure enough the intake from the turbo to intercooler is pretty hot after a hard drive. Car goes into limp mode every time with CEL.
Ive cleaned the maf and intercooler, tried turning off the egr, fuel filter only has 12k mi on it. None of this has helped, also when the CEL is on fuel milage drops in the range of 38-40mpg from 43-45.
This makes highway travel very unfun with the CEL and limp mode.
My brother works for impex so any parts I need to order aint a problem. Ive ordered a new N75 valve.
