Howler
!!! SOLD !!!!
Thanks for all your support in keeping this car running.
The Good
- Rust free (rescued from coastal New Jersey/Philadelphia in 2003)
- PP520 injectors installed <2000 miles ago, tuned by DriveBiWire shop
- Recent tires & brakes
- some suspension & all ball joints renewed at ~165,000
- Next timing belt due at 300,000 miles
- all maintenance and fluids are spec and current
- Full leather interior with working but worn heated seats
- Aftermarket stereo
- Weathertek floor mats
- comes with set of 4ea 16" tires/rims ready to mount
- euro headlight switch and Euro glass headlamp assemblies
- glass front fog lights
- rear fog light operated from headlight switch
- replaced relay 109
- 1-1/4 inch receiver with tow hitch and 7-pin wiring installed
- remote door lock installed
- Injector pump rebuilt at 175,000 with new seals
- ~about 38 MPG
- Cruise control works
- AC blows cold (but with foam chunks)
- rear hatch key opener is now working
- I have the sliding rear compartment cover & tracks
- power windows all work
- original turbo still boost great. Replaced diaphragm about 175,000 miles.
The Bad/Known issues
- peeling clearcoat, paint is dull but intact
- parking lot dings
- RF corner marker/reflector missing due to deer
- recently replaced passenger door handle is missing reverse threaded screw
- LF ABS sensor wire broken at steering knuckle, ABS warning lamp ON
- stained rear compartment: used to haul dogs and WVO in rear cargo area
- currently has torque-steer problem due to worn rubber bushings in suspension. Pulls left when accelerating but stops straight. In its present condition the car is driveable, but front end suspension needs this kit at $99.00
http://shopping.boraparts.com/product_info.php?products_id=1117
Car comes with metalnerd timing belt tools, and an injection pump 5-point socket, among other specialty tools.
New head installed, no more coolant leaks, engine runs great, driven about 6K miles since, Original ODO now at 274,xxx miles. Also installed a replacement matching door.
At time of head replacement: performed intake cleaning, & I instructed Shop to carefully inspect and they said timing belt looked in great condition at 30K in. It needs to be replaced at 300,000, or in about 22,000 miles.
The Good
- ~about 38 MPG
- parking lot dings
