Old February 20th, 2018, 16:36   #1
michael7208
Default Engine removal 09 CR
Hey guys I know I can pull the front end of car and remove motor and trans that way, I was just curious could the motor and trans be pulled out from beneath the car that way the air conditioner lines do not need to be broken or is this possible. I am replacing the original motor a cbea with a cjaa. The orginal motor has 212k miles and failing hpfp along with failing dmf. The replacement motor only has 38k. That is my logic, any I am trying to figure out how to pull motor. First time working on a CR motor, lots to learn. Thanks
michael7208 is offline   Reply With Quote
Old February 20th, 2018, 17:12   #2
turbobrick240
turbobrick240's Avatar
I think it would be easier to replace the clutch/flywheel, and swap the hpfp / aux. pump/ injectors from the cjaa to the CBEA with new timing belt components. The cjaa does have a better oil pump drive, and low miles though.
Old February 20th, 2018, 17:51   #3
michael7208
Well I am planning on replacing with the cjaa and keeping the other one for a back up or spare parts.
Old February 20th, 2018, 18:11   #4
turbobrick240
Right on. Do you have a lift? I'd pull the front end if I was doing a swap.
09 CR engine glow plug stuck dieselherb1 VW MKV-A5 Golf/Jettas 0 March 12th, 2017 08:02
Engine not starting. '09, CR, DSG. MÄDDNESSS TDI Power Enhancements 17 July 20th, 2016 13:49
what is bsfc for CR engine 09-14 Little Joe TDI Fuel Economy 4 September 15th, 2014 19:05
Anyone tried adjusting injection quantity on an 09 and up CR engine? Rod Bearing VW MKV-A5 Golf/Jettas 6 September 25th, 2010 06:13
'09 US-spec 140HP CR -> '09 EU-spec 170HP CR (in '06 body) maloosheck TDI Power Enhancements 20 January 13th, 2010 13:40
Page generated in 0.12497 seconds with 11 queries
[Output: 61.87 Kb. compressed to 55.40 Kb. by saving 6.47 Kb. (10.45%)]
