Bolts-n-Hose
So I'm breaking down the head on my ALH to bring it to the shop for cleaning/checking. Removing all the valves to do this. One valve would not come out as easily as the others. All the others I was able to remove by hand but this one I had to press out and with it came shavings of metal on the grooves for the keepers. This valve will not insert into any of the locations so clearly there is something wrong with it. I'm sure now that guide is destroyed which isn't a huge problem because I was planning all new seals/guides anyway.
My question is, what is up with this valve? Clearly I need a new one but why? This valve also was the dirtiest if that makes a difference. Should I do all the valves or just this one? This motor only has 140k on it. To compress the springs I used one of the C clamp style valve spring compressors.
Advice? Opinions?
Advice? Opinions?
