Old February 4th, 2018, 10:15   #1
Mattyoctavia
Default Turbo whine / howl
Hi Guys, advice more than anything please. Iíve had my golf estate With 2.0tdi BMM engine for almost 4 years, done 60,000 miles and pretty much all that time Iíve heard a turbo whine / faint howl. I keep checking for play in the shaft everytimw I drop the oil out ( around 6,000 miles). Thereís a very small amount of play which hasnít got any worse since Iíve owned the car. I maybe worrying over nothing but I have some big trips coming up this year with each trip covering 2-3,000 miles.
Would you guys recommend stripping the turbo, possibly replacing the turbo cartridge and cleaning the vanes or leave well alone? I also use liqui moly oil additive every oil change.
Do I just need to accept the whine is normal and keep going or is it the start of imminent failure? 😬
Thanks everyone 👍
Mattyoctavia is offline   Reply With Quote
Old February 4th, 2018, 10:53   #2
Mattyoctavia
Forgot to add the car has currently 225,000 miles on its original turbo
Old February 5th, 2018, 20:53   #3
narongc73
Are you sure it's turbo whine? Mine still good at 250k miles. Change oil every 15k.
narongc73 is offline   Reply With Quote
Old February 6th, 2018, 10:56   #4
Mattyoctavia
Define a turbo whine. When the engine is hot it’s barely noticeable. If there vanes are getting dirty or carboned up could this make them a little noise?
Old February 6th, 2018, 16:50   #5
narongc73
Not sure about definition but if it is turbo whine, failure isn't far away. Get it replaced ASAP.
Old February 6th, 2018, 17:14   #6
81-1.6
before you go to the expense of replacing your turbo check for boost leaks. I thought my '06 BRM turbo was going out until I discovered the whine was coming from a leak in my intercooler
81-1.6 is offline   Reply With Quote
Old February 7th, 2018, 11:16   #7
Mattyoctavia
My Egr cooler squeals a fair bit and has done since I’ve owned the car. Could that effect the turbo? I’m thinking of blanking my egr but not sure if that will effect the dpf doing its regen?
Old February 10th, 2018, 12:11   #8
Mattyoctavia
Can I ask your advice please guys? As I work for Volkswagen I can buy a new turbocharger for £758 or a referbished one from eBay for £250 or the cartridge for £110 and rebuild it.
What would you guys go for? Thanks all for your help ��
Engine squeal whine growl howl Jettasad VW MKIV-A4 TDIs (VE and PD) 5 December 19th, 2017 19:02
Turbo Howl/Siren under boost--problem? CatchingAmistad TDI Power Enhancements 3 October 30th, 2015 16:21
Turbo whine Terry Capouch TDI 101 1 March 30th, 2013 13:15
BEW Turbo Whine = Turbo Death? TDIdragon VW MKIV-A4 TDIs (VE and PD) 35 March 2nd, 2012 11:57
Turbo howl FireStorm005 VW MKIV-A4 TDIs (VE and PD) 25 April 13th, 2011 20:28
Page generated in 0.17251 seconds with 11 queries
[Output: 80.68 Kb. compressed to 69.46 Kb. by saving 11.22 Kb. (13.90%)]
