Old February 19th, 2018, 17:28   #16
legendman
Fuel Economy: 45 with the A/C on!
Originally Posted by PhunkFX View Post
For whatever reason, the boost gauge was showing the PSI, but it wasn't making power, as it would seem like the air was just not making it out.... so the ECU would be calling for certain power levels, and the car would up the PSI to try to get it, but couldn't maintain it consistently. From what I can gather.
Thanks for the update.
This is how mine is, it sounds like it's choking on itself when the boost goes.
If I let off or give it a good amount of throttle it will clear out only to start the cycle over again.
I am going to try the zip tie mod and cleaning the turbo as I just dumped a bunch of money on a cam and timing belt kit.
2006 Jetta 5SP 187k ..stock..for now
legendman is offline   Reply With Quote
Old February 19th, 2018, 22:59   #17
PhunkFX
PhunkFX's Avatar
Fuel Economy: 44-46 MPG
Yeah, I was in the same place. So rest assured, its not likely your block or head or something major. In order to figure this out, which I pretty much new it was the turbo right away, I replaced the N75 valve, the tandem pump (was having check valve issues), the valve cover, various vacuum lines, MAF, tune (twice), and even tried cleaning it with ez-off oven cleaner during the down pipe upgrade.
I did not try the zip-tie mod, which could have worked, idk. LOL But I'm all sorted now with fresh ancillary parts. So I'm happy. Not it's just a tuning game for me.
Good luck to you, sir.
-Ricky
2005.5 VW Jetta TDI 6MT | 185K Miles |
PhunkFX is offline   Reply With Quote
BRM Low boost below 1800rpm issue OMALLEY_808 VW MKV-A5 Golf/Jettas 20 June 24th, 2016 08:56
Good used BRM bv39 Turbo w/actuator plus additional actuator only. 46237 newlitemotorist Private TDI Items for Sale/Wanted 9 September 17th, 2014 15:19
BRM EGR issue / ? Boost 10then34 VW MKV-A5 Golf/Jettas 3 May 15th, 2014 22:00
brm turbo actuator issue delslo VW MKV-A5 Golf/Jettas 2 March 8th, 2011 06:58
Strange boost activity. Rover96 TDI Power Enhancements 2 July 27th, 2008 06:27
Page generated in 0.13796 seconds with 11 queries
[Output: 56.69 Kb. compressed to 52.25 Kb. by saving 4.44 Kb. (7.84%)]
