Old March 20th, 2017, 06:24   #1
PhunkFX
PhunkFX's Avatar
Fuel Economy: 44-46 MPG
Default Video: BRM Boost Hunting / Surge/Blip -- Activity Possible Actuator Issue?
This is a short video illustrating the weird blips and surges I experience while on a steady throttle or cruise control. The blip and surge is momentary and only noticed the instant before this weird boost spike drops off and goes down to normal expected boost.
VIDEO: https://youtu.be/Zrb4Pp39K9w -- the buzzing you hear is the boost gauge itself. (supposed to be a no-buzz fitting )
This is the behavior I witnessed after installing my boost gauge on 19 March 2017. The evidence via the boost gauge is very interesting. At first, I thought there was something wrong with my gauge!!
Odd boost hunting that occurs at random. No rhyme or reason. Notice my MPH and RPM do not move, as I'm set at ~80mph on cruise. During the duration of the increased boost, I notice (feel nor hear) anything different in the running. I notice a small surge of power, or blip right before the boost falls off down to ~4-5psi, as stated previously.
Crazy huh? What do you think?
-Ricky
2005.5 VW Jetta TDI 6MT | 185K Miles |
PhunkFX is offline   Reply With Quote
Old March 20th, 2017, 06:41   #2
PhunkFX
PhunkFX's Avatar
I'll be taking some VCDS logs / graphs on the way home. That should be very telling as well. Perhaps all I may need is a new N75. We'll see. I'd rather figure this out, than throw hardware at it until it's resolved. You know, for future information.
R
-Ricky
Old March 20th, 2017, 08:49   #3
JETaah
Fuel Economy: 53 max, 42 min, average 46
I dealt with the same problem as you describe on a customer's car. (wonder if it is the same one).
At a steady speed of around 45 and up, the boost would work it's way up to 20-25PSI and then drop to about 6PSI and start the cycle over. At 80MPH it would cycle every 5 seconds or so. Really annoying.
The closest that I could get to resolving the surges was to stiffen up the actuator until it just started to move the lever with 9"hg vacuum and pull back on the stop screw adjustment. Anymore than that and it would throw an implausible code for the position sensor.
The customer had been through a lot expenses with the car, (transmission, clutch, camshaft, timing belt,... he had just bought the previous owner's nightmare), and did not want to shell out more for a new turbo or even remove it to see what was going on with the vane mechanism. Chances are that the vanes were distorted. Disconnecting the vacuum to the actuator produced a lag in the boost at low RPMs but otherwise gave all the boost that it needed.
This car was chipped but not above a stage1.5-2.
Try to see if the car runs fairly normal without vacuum to the actuator.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old March 20th, 2017, 09:36   #4
PhunkFX
PhunkFX's Avatar
I'll be sure to check that... It may be a tuning issue... I'm still looking into it. As I have deleted the EGR and ASV, my custom tune may not have it corrected.
Then again, I'll grab some logs on my commute home, tonight.
-Ricky
Old March 20th, 2017, 15:58   #5
PhunkFX
PhunkFX's Avatar
-Ricky
Old March 22nd, 2017, 17:17   #6
Kalter|Tod
research the zip tie mod..... This will fix all those problems..... I run a Stage 2 tuned car and this fixed all the above problems...... Zip tie Mod is your friend
Kalter|Tod is offline   Reply With Quote
Old March 23rd, 2017, 05:51   #7
DonsJetta
Fuel Economy: Now 40mpg!
Is the zip tie mod used as a limiter or, does it increase the spring rate at the end of the stroke? One reason I ask is because a zip tie cannot be loosened if you go to far, it must be cut and re-installed..
DonsJetta is offline   Reply With Quote
Old March 23rd, 2017, 06:14   #8
PhunkFX
PhunkFX's Avatar
Good Question!
-Ricky
Old March 23rd, 2017, 06:52   #9
JETaah
Zip tie is a stroke limiter.
Old March 23rd, 2017, 07:32   #10
DonsJetta
OK good! I used a foot of stainless safety wire folded in half and made a small loop to just fit over the end of the actuator rod, pulled around 17 to 18 in/vac, then twisted the wires together over the vacuum port nipple. Allot easier than trying to loop a zip tie for me anyway. I did have to attach a light weight spring to keep the wire loop against the rod adjusting nut as the rod moved through it's stroke during operation. Without the spring, the wire loop would slide down the threaded rod and lock, limiting the travel and throwing a code. So far its working well.
Old March 23rd, 2017, 07:35   #11
JETaah
A byproduct of shortening the stroke (zip tie mod) is that it requires less vacuum to reach the max boost position.
You would have to increase the actuator rod preload to maintain the original relationship of (X)"hg = max boost position.
Old March 23rd, 2017, 07:36   #12
PhunkFX
PhunkFX's Avatar
I think the majority of my problem is tuning related. But I do have a vacuum related issue as well. I probably did not re-attach some kind of important vac line, or I plugged the wrong one, after the full EGR/ASV delete.
I'm not entirely worried about overboosting with the turbo, I am going to get a much safer tune soon. But likely sometime this summer, I am going to upgrade the turbo, just because I want better flow, possible MPG, and more power. Aka, yes I'm greedy.
-Ricky
Old March 23rd, 2017, 07:52   #13
PhunkFX
PhunkFX's Avatar
And then ultimately my nozzles... and I'm in need of a clutch now, and the flywheels makes so much noise as the clutch is pressed down.
Man, buying a fully stock vehicle entails a log when you want to modify it I'm very happy with it however. I'll make a separate post of it's transformation.
-Ricky
Old February 16th, 2018, 15:25   #14
legendman
Fuel Economy: 45 with the A/C on!
PhunFX did you get this sorted out?
My boost gauge is doing the same as yours, goes up to 20lbs then drops
with cruise set to 70 mph
2006 Jetta 5SP 187k ..stock..for now
legendman is offline   Reply With Quote
Old February 18th, 2018, 08:10   #15
PhunkFX
PhunkFX's Avatar
I did. It was the actuator and/or clogged or sticking VNT vanes. I upgraded my turbo, as I wanted more power. This issue completely cleared up.
For whatever reason, the boost gauge was showing the PSI, but it wasn't making power, as it would seem like the air was just not making it out.... so the ECU would be calling for certain power levels, and the car would up the PSI to try to get it, but couldn't maintain it consistently. From what I can gather.
New turbo with no smart actuator, and a new tune for the turbo sorted this all out!
-Ricky
BRM Low boost below 1800rpm issue OMALLEY_808 VW MKV-A5 Golf/Jettas 20 June 24th, 2016 08:56
Good used BRM bv39 Turbo w/actuator plus additional actuator only. 46237 newlitemotorist Private TDI Items for Sale/Wanted 9 September 17th, 2014 15:19
BRM EGR issue / ? Boost 10then34 VW MKV-A5 Golf/Jettas 3 May 15th, 2014 22:00
brm turbo actuator issue delslo VW MKV-A5 Golf/Jettas 2 March 8th, 2011 06:58
Strange boost activity. Rover96 TDI Power Enhancements 2 July 27th, 2008 06:27
Page generated in 0.15222 seconds with 11 queries
[Output: 128.41 Kb. compressed to 106.85 Kb. by saving 21.57 Kb. (16.80%)]
