I drove my 98 TDI to Mexico. I am being told by VW in Guadalajara that the injectors need to be replaced. The check engine light is on. I noticed a sudden loss of power when I was trying to pass a truck with a lot of black smoke out the back. The power loss is not as much as when the turbo has died, but it noticeable on the hills. I have been very good about using Techron in the tank. The car has 230k on it. Could the injectors be clogged? Is it the injectors or the nozzles that might be bad? Generally do you replace all four or just the bad one? The fuel here is not good, should I be using an additive.
