there's a lot of trans code/engine code dyslexia going on in this thread ... ANY mkiv tdi trans is interchangeable with any other mkiv tdi trans, however, if you use a DQY (pre y2k mkiv) in a y2k or later mkiv you need to swap the DQY's early 02A tower for the 02J tower ... just to be clear, ALH is NOT a trans code, it's the engine code, and that engine came with three different 02J trans codes: DQY (early with 02A tower), EBJ, EGR, ... late mkiv BEW PD engine code came with two different 02J transmissions: EUH (jetta/golf) and EGS (beetle) ....also not all 02J towers are created equal, aside from the obvious early 02A outlier, the early 02J style tower has a round lower shaft as opposed to the late style which has a double "D" grooved lower shaft ... they can also be freely interchanged but if using an early round shaft in a late D shaft trans you must replace the lower shaft support or remove the detent spring... the late D type shaft is 100% reverse compatible with all 02A/02J trannies
