Hi all,
06 Jetta BRM with 149k miles.
I just installed a Stage 3 Colt cam. I was under the impression that adjusting the injector lash was not necessary when swapping cams, so I didn't. Due to ignorance I never checked the injector quantity block with the old cam but now in VCDS it shows cyls #1 and #3 are within spec (with #3 being just a few hundredths off of zero) and #'s 2 and 4 are waaay off. Something like +1.8 and -1. Yes, rockers were installed in their prior positions.
I've read that when one injector is off, it's counterpart (2 with 4 or vice versa, in my case) will show compensation behavior. Dunno much about this, but anyhow, can this type of off reading be corrected by adjusting the lash? I've read posts by folks that adjust lash as per Bentley only to find their numbers worsen. I'm guessing that I shouldn't have to touch #'s 1 and 3 in my case, right? (Although I'm considering carefully marking the current position of #1 or #3 and then seeing how far from bottom it is, to use as a baseline for the others and contrast that to the Bentley spec in case they differ.) Also, I've seen many posts by folks that used Diesel Purge and posted their before and after IQ figures, but the differences have never amounted to that much, certainly not something as off as my #2 and 4 are, but I could definitely be wrong about that. So whaddya think?
Car is driving MANY times better than before my cam swap, I just want to fine tune everything now. The thing is, performance was so poor prior to the new cam and actuator that I have long ago forgotten what "right" is. Only overt thing I see is that it stutters/misses a bit when I rev past 2k and let go of the throttle abruptly. Does this no matter what I set for torsion (left it at 1.0 for now, since 0.5 eluded me) and the new actuator is just a quarter turn of the stop screw away from being spot on.
In short:
1- Are these IQ numbers possibly just due to lash?
2- If no, what should I do about the IQ? Or else what can happen?
Thanks!
In short:
Thanks!
