Is anyone having problems with their accessory belt cracking? Awhile back, I failed a state inspection because I had a crack in my accessory belt (longitudinal crack) about 1/3 of way from the right side of the belt when looking at it from above. It's not along the entire length of the belt. I had it replaced at a VW dealer, and about 30K later, I had a guru in Fort Worth do a timing belt job on it. Since the accessory belt was included, I had it replaced also. I didn't notice any cracks in the one that came off.
Today, when doing an oil change and fuel filter change, I noticed it's cracked again, in the same place. In fact, it looks like the top "layer" of the belt is gone, about 1/3 of the width from the right side of the belt, and again, not along the entire length of the belt.
Any ideas on what might be causing this? TIA.
