VW_Factor
- Joined
- Jul 31, 2009
- Location
- Leesburg, Georgia
- TDI
- 2003 Jetta, 2009 Jetta, 2020 Passat R-Line Gasser
Wow.. Good information here..
Lotsa bull**** too.
Lotsa bull**** too.
dvst8r said:The only thing I want to add, is that I think it is funny that some how truck or tractor nozzles are crude, and that people don't have $400K to spend on a machine, I personally know several SMALL business owners that spend that kinda money every year just to go racing, let alone, on something that makes them money.
Upgraded injectors for direct injection diesel trucks have been produced since the early 90's The first VW TDI available wasn't till the late 90's, so with out taking into account tractors, that is nearly a decade more R&D time. Unlike the TDI market place where there are 3 maybe 4 injector manufacturer's there are at least a dozen aftermarket injector manufacturer's in the truck and tractor world. You think that after nearly 3 decades of competition that some how there technology isn't as good as TDI injector technology?
TDI's are small money, TDI injectors are small money, TDI R&D is small money. I have held in my hands a billet injection pump for a competition tractor that worth the same $$$ as a new TDI. It was in the pits for a spare. In the TDI aftermarket people balk at spending $2000, in the truck world that doesn't even get you a transmission.
To me the most ironic part of all of this is; the highest HP vw tdi in north america runs a set of custom edm'd cummins nozzles in machined TDI bodies, from neither of these vendors. Oh and just because you don't know about it doesn't mean its not out there.
Nick, I am glad that you posted the information, it doesn't mean much to me other then relative sizing, but any information is better then no information. The one thing that I feel was missed was spray angles, as this has a big impact on injector performance. Unless of course all of the above injectors use the same spray angle.
To finalize what has become a bit of a novel, I don't run either of these vendor's injectors. I am just sick of hearing how aftermarket truck injectors are some how inferior to aftermarket TDI injectors.
Not the only one. Note what he said:stefan_b said:Personally, I think that for me the best option would be to go with Bosch. I believe there is consensus that Bosch delivers a quality product if the aim is to stay close to spec.
I also learned one thing - as good a job as DBW did, he clearly stated that HE - thus not a mere user like me - is missing flow characteristics and/or quantitative/qualitative parameters for non-OEM nozzles. And again, DBW confirmed that Bosch does provide reference nozzles, and is the only one doing so.
dated 10/28/04:I think I can cover all the power levels with one nozzle. Maybe two. Even with less smoke, we can make the HP/TQ.
I dont currently sell any TDI products. Im working on TDI nozzles as of two weeks ago! LOL Getting my feet wet, so to speak. Im pretty much fresh out of the oven, but not half baked.
Im in Dallas. I use dealers to sell products for me now. I dont direct sell anything to the public. Its all Dodge Cummins, Ford Navistar, and Duramax Izuzu injectors only. A few hardcore hard parts ( camshafts, injection pumps, etc ) We dont have a store front. Its a manufacturing and distributing operation only.
I want in on the TDI market. Its not large and the money is certainly not there, but I need a new challenge. The injectors we have for the Cummins have really made postive changes to the entire market. Hopefully we can apply it to the TDI and the PD
Don~
F1Diesel said:I have to tell you guys that flow testing nozzles with 50 PSI of shop air using a cheesy litres/liters per minute gage is a joke. While air is a fluid it reacts nothing like ISO test oil at 100 bar and up when flowing through a Diesel nozzle.
At a minimum, you need temperature controlled ISO test oil at 100 bar. Some use Shell. Some use other brands, but if it meets ISO 4113 specs it should be fine. We use Viscor. Hundreds of gallons a year.
I have a little knowledge in this subject.
I don't speak for Ndamico, but the issue with the 7 hole R520 (PP764 too?) is the uneven hole spacing. I have heard the 7 hole PP764 have the same odd spacing as the 7 Hole R520. Why is this done? The pattern looks like it is a 5 hole nozzle with 2 holes added in between some holes.gbosio said:To Ndamico: please, I made a couple of questions and I would like your reply, if it's possible. And I have another one: I would like to understand why you don't like PP 764 with 7 holes.
Thanks to all of you
Whitbread said:Mr. Bosio, I understand what you're saying about the hole geometry, but I disagree with some things. The spray cone you refer to definitely does not end up dispersing the fuel evenly. The flame patters on this piston clearly indicate it.
In this motor, the angle of the holes was different between the injectors. In that piston pictured above, you can clearly see the flame marks on top of the piston where they shouldn't be. On the other 3 pistons, the flame marks are inside the bowl where they should be.
These were 7 hole race injectors installed and pop tested by a very reputable individual with only 5k miles on them when the motor was torn down.
I do agree that fuel is not distributed evenly across that combustion bowl and I think that has to be the main problem with Bosio 7 hole design. I'm sure that seven hole strategy is better than five hole, but holes need to be more evenly distributed. Like Hatemi said, enough comparing test have been already made to verify this (OK, I have to admit that we are just doing this as a hobby with no qualifying education what so ever...)Whitbread said:Mr. Bosio, I understand what you're saying about the hole geometry, but I disagree with some things. The spray cone you refer to definitely does not end up dispersing the fuel evenly. The flame patters on this piston clearly indicate it.
The first and second stage pop pressures were set by one of the professionals here who only does VW injectors. There was also less than 5K miles on that set of injectors. What else would make the flame patterns so different? 3 pistons were identical, 1 was an oddball. I checked injector protrusion on the bottom side of the head and all the injectors were even. One of the rods in the motor was compressed by ~1mm but it wasn't the cylinder that piston came out of.shadowmaker said:On the second matter (flame marks on top of that piston), are you sure that it's due to different angle between injectors? I mean, have you got those nozzles tested somewhere to verify this? I would suspect different "actual SOI" between cylinders to be reason for this.
I have seen this so many times before (only one piston has flame marks on top of it, even on Bosch nozzles). I just don't know why. I suspect nozzle manufactures must have strict tolerances regarding spray angle due to tooling methods? Mr. Bosio?Whitbread said:The first and second stage pop pressures were set by one of the professionals here who only does VW injectors. There was also less than 5K miles on that set of injectors. What else would make the flame patterns so different? 3 pistons were identical, 1 was an oddball. I checked injector protrusion on the bottom side of the head and all the injectors were even. One of the rods in the motor was compressed by ~1mm but it wasn't the cylinder that piston came out of.
This is how I see it:robnitro said:I've drawn up a crude picture of stock 5 hole, 7 Hole R520, and the evenly spaced 7 hole configuation. I based it on photos seen of spray patterns and of nozzle holes, so it is not 100% accurate, but close enough to illustrate the issues being brought up.
You can see how in the 7 hole nozzle, the holes are clumped on one side, unevenly- by the "center line" through 2 holes and the center of the nozzle.
The stock 5 hole and the ideal 7 hole configurations don't have a drastic imbalance of holes to sides as the 2R520's do.
Mr. Bosio, why wouldn't the geometric septagon pattern be better than an unevenly spaced pattern??? The stock nozzle has 72 degrees between holes, the septagon pattern has 51.4 degrees between holes, yet your design seems to have 45 degrees between holes (top half) and 60 degrees between holes on the bottom half. If the uneven hole pattern is ideal, why is the stock 5 hole an even hole pattern (evenly 5 sided)?
All 4 pistons belonged to the same engine. All 4 injectors were the 7 hole R520's with about 5k miles on the injectors. The cleaned up piston I showed has a crack in it at the 3 o'clock position and you can clearly see 3 clumped heat marks at 11,12, and 1 with the others at 2:30, 5, 7, and 9:30. The engine was an ALH. The other 3 pistons had the heat marks in the bowl of the piston where they should be. Still unevenly spaced, but not on the top of the piston. Did you want to examine the damaged piston, the nozzles, or both?gbosio said:Whitbread, please I need some more info. Do the 4 pistons belong to the same engine or not? Or does the first photo show a piston damaged buy a 7 holes nozzle and the second one 3 pistons as they should be? If the 4 pistons belong to the same engine, can you tell me if in every cilinder there was a 7 holes installed and which one? Which is this type of engine and which are the stock nozzles? Eventually can you send them to me to analize?
