Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old February 16th, 2020, 08:16   #16
Twglace
Originally Posted by alext91 View Post
Awesome, best of luck!
I did the job yesterday. Only took me about 4 hours and I pulled out the axles .... it was super simple only thing that was a pain was getting the knuckle back into place on the passenger side. That axle doesnít give you much to work with lol.
2013 Jetta sportwagen Cjaa 2.0 TDI DSG 118k
Twglace is offline   Reply With Quote
Old February 16th, 2020, 08:18   #17
alext91
alext91's Avatar
Nice!! 4 hours isn't too bad for a first time.
Sent from my SM-G960U using Tapatalk
2013 Jetta Sportwagen TDI 6MT Pano, Candy White
2015 Golf TDI S 4DR 6MT (Wife's)
2015 Yamaha FJ-09
1999.5 Jetta TDI Tornado Red (Sold)
1996 Yamaha FZR 600 (Sold)
alext91 is offline   Reply With Quote
Old February 16th, 2020, 08:23   #18
Twglace
Driving it for the first time after doing this it feels alittle crunchy.... I triple checked to make sure I reassembled the strut assemblies correct. Any advice on what to check ? Or if itís normal?
Old February 16th, 2020, 08:27   #19
Twglace
Nothing is loose it feels almost like a giant grinding like somethingís rubbing
Old February 16th, 2020, 09:30   #20
Twglace
Faint***
Old February 16th, 2020, 11:13   #21
da.hs
Grinding sound related to car bouncing over uneven ground or to wheel speed?
da.hs is offline   Reply With Quote
Old February 16th, 2020, 11:17   #22
alext91
alext91's Avatar
Is this happening all the time while driving? Or when turning, etc. ?
2015 Yamaha FJ-09
Old February 16th, 2020, 15:45   #23
abishoff
Default Tips or tricks from MK6 front strut replacement
What struts did you use? Are you sure you got the knuckles tight enough around the strut? Iím not sure what the torque rating is.
abishoff is online now   Reply With Quote
Old February 16th, 2020, 16:27   #24
Twglace
All the time when driving.... sounds like wheel bearing TBH...
Old February 16th, 2020, 16:29   #25
Twglace
Bilstein b4s and yes I torqued them with 105nm.
Old February 16th, 2020, 16:31   #26
Twglace
Wheel speed
Old February 16th, 2020, 16:35   #27
Twglace
Itís 100% a rotational grinding could is it possible I f*** up the axles? Or possibly change the pitch of the bearings ?? Iím pissed at myself at the moment lol.... plus I am taking a road trip in the damn thing Wednesday night...
Old February 16th, 2020, 16:35   #28
abishoff
Iíve been having some issues since I did mine. Iím caught between not tightening the knuckle enough, possibly and subframe issue cause I did a new front swaybar on, or the springs moving. Mine seems mostly while turning at low speed.
Old February 16th, 2020, 16:37   #29
alext91
alext91's Avatar
Jack the wheel up and spin it to identify the sound.
2015 Yamaha FJ-09
Old February 16th, 2020, 16:38   #30
Twglace
I did my sway bar links as well but yeah thatís one thing I tried Is turned the wheel all the way both directions and no clunking nothing at all... struts seem to be solid.... honestly other than the grinding and very slight vibration it drives much better than before....
Can't get the front top strut bolt to come loose. Any tricks to it? invader VW MKV-A5 Golf/Jettas 6 December 10th, 2014 17:36
PD Thermostat replacement tips and tricks? Forza91 VW MKIV-A4 TDIs (VE and PD) 17 January 14th, 2013 03:32
strut replacement tips greenskeeper VW MKIII-A3/B4 TDIs 19 December 18th, 2008 06:33
Strut/shock replacement tips? Paul_L_Fisher VW MKIV-A4 TDIs (VE and PD) 19 August 10th, 2005 08:35
A4 turbo replacement tips & tricks Tom_S VW MKIV-A4 TDIs (VE and PD) 2 August 9th, 2004 22:08
Page generated in 0.15741 seconds with 11 queries
[Output: 125.93 Kb. compressed to 104.71 Kb. by saving 21.22 Kb. (16.85%)]
