solarmike
- Joined
- Dec 16, 2005
- Location
- Bend, Oregon USA
- TDI
- '00 Beetle TDI, Vanagon Syncro with front and rear lockers, non viscous coupler, with decoupler waiting for a TDI swap
I have taken my turbo out and replaced 5 times ( same turbo vanes kept sticking) finally found the problem and corrected it but, now it won't start. It turns over no problem just won't start. I believe it is fuel related because when I opened the 3 injector line at the injector and no fuel comes out while cranking. The car has been showing no problems and had been running great. I have done this job so many times and never a problem with starting. All hoses and vacuum lines are good no fuel leaks anywhere and injection pump is new. What gives? I read the voltage at the fuel sending unit and get about 5 volts constant whether the ignition is on and while cranking, no change in voltage. Is this a problem?
