Giberish33
My 97 Jetta has been showing signs that the control arm bushings are going bad, they were changed once before a few years ago and the car was exhibiting the same symptoms then once replaced it was fine again. What is happening is when letting off the throttle the steering will go a little slack and the car will pull to the left, then get back on the throttle and the car goes right and steering gets tight again.
I intend to change the rear bushing with either poly or the TT bushing and want to know what diameter I need to look for when buying a press kit. There are some more basic ones that only come with like 4 different cup sizes and I don't want to buy one then find out I don't have the correct size.
Anyone know what sizes or specific kit to look for to press out / in both the front and rear bushings on the control arms?
Thanks.
Thanks.
