I recently bought a 2005 Passat wagon 2.0 TDI for a really good price because it had a boost code
and the owner didn't want to pay the dealership their quoted price to get it fixed.
I would appreciate any advice on what to do to get this running and the best order of operations, story follows...
I was able to drive it home (in limp mode?) and the next day it wouldn't start. I ran the battery down
trying to start it (This is my first diesel and my first VW that isn't a beetle...I know better now).
I ordered a Vag-Com and a repair manual that I was assured included this model hoping that would be all I needed...
of course it doesn't cover this engine.
While I was waiting for the Vag-Com I did the following:
- Disconnected battery(attempting to reset the immobilizer) and charged the battery,
-Replaced the 219 relay as I have read that it is a common cause of the codes that I had from my OBD
-Visibly inspected all the hoses and vac lines,
-Pulled the MAF, it appears to be a new one to go with the brand new air filter,
-Put a mighty vac on the actuator and watched it push the rod down and back up a few times,
couldn't see it well enough to be able to note exact pressure.
-Pulled the intake air hose off the turbo(there was a couple drops worth of oil in there)
and spun the turbo with my finger(rotates but doesn't "spin" on it's own, should it?), checked for in-out play(none),
-Was able to start the car when the Vag-com came, reading are as follows:
VIN: WVWCE63B95E116080 License Plate:
Mileage: 326190km-202685mi Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWCE63B95E116080 Mileage: 326190km/202685miles
Address 01: Engine Labels: 038-906-016-BHW.lbl
Part No SW: 038 997 016 T HW: 028 101 198 2
Component: R4 2,0L EDC G000AG 0314
Revision: 12345678 Serial number: VWZ7Z0D1096047
Coding: 0150034
Shop #: WSC 23312 444 84483
VCID: 2F6DF537BDE897663D9-5072
4 Faults Found:
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 1470 /min
Torque: 0.0 Nm
Speed: 57.0 km/h
Temperature: 27.0°C
(no units): 25.2
(no units): 0.82
Temperature: 75.6°C
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
RPM: 924 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001000
Bin. Bits: 11000000
(no units): 0.0
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2394 /min
Torque: 240.0 Nm
Speed: 64.0 km/h
Load: 54.9 %
Voltage: 13.98 V
Bin. Bits: 00001000
Absolute Pres.: 2264.4 mbar
Absolute Pres.: 1764.6 mbar
17586 - Linear O2 Sensor; Pump Current
P1178 - 000 - Open Circuit
Freeze Frame:
RPM: 2520 /min
Torque: 120.0 Nm
Speed: 48.0 km/h
Load: 31.0 %
Mass Air / Rev.: 420.0 mg/str
(no units): 0.20
(no units): 8.0
Bin. Bits: 10001001
Readiness: 1 2 0 0 0
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 24470A1BB42E243ED0B-5000
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 15235
Shop #: WSC 39035
VCID: 275D1D17C518CF26F59-5000
WVWCE63B95E116080 VWZ7Z0D1096047
1 Fault Found:
01304 - Radio
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 25016
VCID: F0EFB64BB056489EE43-5072
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0001
Coding: 00258
Shop #: WSC 00028
VCID: 377DCD5715B85FA6659-4A9C
Subsystem 1 - Part No: 1C1959801
Component: 80 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 80 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 80 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 80 Tõrsteuer.HR KLO 0202
10 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
27-10 - Implausible Signal - Intermittent
01334 - Door Control Module; Rear Right (J389)
27-00 - Implausible Signal
End ---------------------------------------------------------------------
Things on my current "to-do" list are:
-Remove and clean out EGR,
-Replace N75 just in case,
-Find O2 sensor and attempt to replace it,
What should I be doing and what have I missed?
Coding: 0150034
4 Faults Found:
Freeze Frame:
RPM: 1470 /min
Torque: 0.0 Nm
Speed: 57.0 km/h
Temperature: 27.0°C
(no units): 25.2
(no units): 0.82
Temperature: 75.6°C
Freeze Frame:
RPM: 924 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001000
Bin. Bits: 11000000
(no units): 0.0
Freeze Frame:
RPM: 2394 /min
Torque: 240.0 Nm
Speed: 64.0 km/h
Load: 54.9 %
Voltage: 13.98 V
Bin. Bits: 00001000
Freeze Frame:
RPM: 2520 /min
Torque: 120.0 Nm
Speed: 48.0 km/h
Load: 31.0 %
(no units): 0.20
(no units): 8.0
Bin. Bits: 10001001
Coding: 12345
Shop #: WSC 05311
1 Fault Found:
Coding: 15235
Shop #: WSC 39035
1 Fault Found:
01304 - Radio
Coding: 00006
Shop #: WSC 25016
1 Fault Found:
01304 - Radio
Coding: 00258
Shop #: WSC 00028
10 Faults Found:
