Old January 10th, 2020, 06:56   #31
borjawil
Awesome, thanks for the info. How do I go about reading voltages for the crank sensor wiring with the vcds (if that's possible)? Hard to get to without removing the oil filter housing to check with my meter.
Already replaced the fuel filter so I hope it's not that. Couple questions though. The lid on the fuel filter housing, how pertinent is it to be flush/sealed? One of the bolts stripped out, and that area of the lid has a gap about 1/8" where as the rest is flush.
I also noticed on the inside of the lid, there's a plastic portion that seats against the top of the filter. There's an o ring around this. When removing it, I noticed a small hole just below the oring groove. Maybe an 1/8" in diameter, though I wouldn't say it's a circle. That's why I'm asking as it's not a circle and almost looks like a tool or something punctured it. Not sure if this is normal or if it would affect anything, as the lid seems to just seal the fuel filter housing, and that's done alabove the hole at the o ring. Though I'm not sure how the fuel feed, return, and whatever the 3rd line is, work inside/through the lid.
Sent from my moto e5 plus using Tapatalk
borjawil is offline   Reply With Quote
Old January 11th, 2020, 08:56   #32
borjawil
got the autoscan done, went through the document and deleted anything with no fault found. Note that the driver door electric shows a fault due to the **** harness VW skimped on. I have non stock tires for the pressure sensors. I disconnected the cam sensor plug and maf plug trying to see if id get a change in the running condition, likely why those are on there, but not 100%. Also have an aftermarket touchscreen from Eonon installed.
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
72 7D
VIN: 3VWFT71K46M852588 Mileage: 393260km-244360miles
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H05--- Serial number: VWZ7Z0F9021111
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 6491AB6F425215874DF-8030
6 Faults Found:
005269 - Switch-Over Valve for EGR Cooler (N345)
P1495 - 000 - Open or Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 393266 km
Time Indication: 0
Date: 2000.00.00
Time: 17:08:21
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.77 V
Bin. Bits: 00101000
Mass Air / Rev.: 1000.0 mg/str
Mass Air / Rev.: 0.0 mg/str
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 393266 km
Time Indication: 0
Date: 2000.00.00
Time: 10:18:24
Freeze Frame:
RPM: 126 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.10 V
Bin. Bits: 00101000
Temperature: 6.3C
Bin. Bits: 01110000
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 393266 km
Time Indication: 0
Date: 2000.00.00
Time: 10:18:24
Freeze Frame:
RPM: 126 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.10 V
Bin. Bits: 00101000
Temperature: 6.3C
Bin. Bits: 01110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 393266 km
Time Indication: 0
Date: 2000.00.00
Time: 10:18:24
Freeze Frame:
RPM: 126 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.10 V
Bin. Bits: 00101000
Temperature: 6.3C
Bin. Bits: 01110000
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 393267 km
Time Indication: 0
Date: 2000.00.00
Time: 10:58:53
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 100.6 %
Bin. Bits: 00101000
Mass Air / Rev.: 465.0 mg/str
012295 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 393267 km
Time Indication: 0
Date: 2000.00.00
Time: 10:12:22
Freeze Frame:
RPM: 777 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.67 V
Bin. Bits: 00101000
Idle Stabilization: 0.0KW
(no units): 48.0
Readiness: 1 4 0 0 0
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000499498
Coding: 14018E234004150007140000001400000028770B5C0000
VCID: 372B2C23A3442E1F38D-8062
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 051206 020 0501
Coding: 00065535
Shop #: WSC 00066
3 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 81
Mileage: 333390 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.45 V
ON
ON
OFF
OFF
ON
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 81
Mileage: 342504 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.55 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 254
Reset counter: 121
Mileage: 345431 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.45 V
ON
ON
OFF
OFF
ON
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D078GYC
Coding: 0013889
VCID: 6C81C34FAA825DC705F-8038
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME132E7F41I
Subsystem 3 - Serial number: 6342MSME12465F7DP
Subsystem 4 - Serial number: 6351HSME0B421D59C
Subsystem 5 - Serial number: 6361HSME0B3C4E6AS
Subsystem 6 - Serial number: 63727SME0B2F214A5
Subsystem 7 - Serial number: 63827SME0B2F186AE
4 Faults Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
008 - Implausible Signal - Intermittent - MIL ON
010 - Open or Short to Plus - Intermittent - MIL ON
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent - MIL ON
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
003 - Mechanical Failure - Intermittent - MIL ON
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001069221977
Coding: 3FBF0B620F001002
VCID: 2C01034F6A029DC745F-8078
2 Faults Found:
02649 - Digital Radio Tuner
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 343781 km
Time Indication: 0
Date: 2000.00.00
Time: 02:51:32
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 390101 km
Time Indication: 0
Date: 2000.00.00
Time: 13:41:28
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 32008001 Serial number: 00000047469129
Coding: 0001205
VCID: 3B2330139F6C0A7FDC5-806E
3 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 85
Mileage: 0 km
Time Indication: 0
01552 - Motor for Central Locking; Drivers Door (V56); Lock
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 31
Reset counter: 113
Mileage: 384077 km
Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Reset counter: 81
Mileage: 0 km
Time Indication: 0
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000101911
Shop #: WSC 00000 000 00000
VCID: 2A0D055760F683F7B73-807E
4 Faults Found:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
00876 - Treble Speaker Rear Left (R14)
006 - Short to Plus
00877 - Treble Speaker Rear Right (R16)
006 - Short to Plus
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 32008001 Serial number: 00000586069110
Coding: 0001204
VCID: 3C21330F9A620D47D5F-8068
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Freeze Frame:
Fault Priority: 5
Reset counter: 121
Mileage: 250462 km
Time Indication: 0
Address 56: Radio Labels:
VCID: 55F786AB1C08FC0FCA1-FFFE
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000799384
Coding: 0001168
VCID: 3E2539078C7E1F57FBB-806A
2 Faults Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
Freeze Frame:
Fault Status: 01111000
Fault Priority: 3
Reset counter: 81
Mileage: 329796 km
Time Indication: 0
01554 - Motors for Central Locking; Rear Doors; Lock
Freeze Frame:
Fault Status: 01111100
Fault Priority: 3
Reset counter: 81
Mileage: 329796 km
Time Indication: 0
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: RDK 0420
Revision: 00051000 Serial number: 00000000000000
Coding: 0100101
Shop #: WSC 131071 1023 2097151
VCID: 74B1DB2FF2B28507DDF-8020
1 Fault Found:
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 41
Mileage: 390122 km
Time Indication: 0
Date: 2000.00.00
Time: 10:25:04
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D070E4B511894CF521-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 01:48, VBatt start/end: 12.3V/12.3V)-----------
Old January 11th, 2020, 08:59   #33
borjawil
Here are the values I knew to get. Where do I check my timing? I looked on Ross tech and it said to go to group 000 then click switch to basic. Won't allow me to go to group 000 and the switch to basic button is greyed out.
Old January 12th, 2020, 05:17   #34
crazyrunner33
crazyrunner33's Avatar
I'll have to drink some coffee and look at this on the bigger monitor. Some notes:
1) on the fuel filter housing, if it's not sealed enough and is allowing air in, it'd definitely create a rough running engine. I haven't dealt with those issues on the TDIs I've owned, but I know from other diesels that it's possible to leak air into the system without leaking fuel back out
2) your recorded cam position sensor fault came at around the the same time as your glow plugs faults. That can be a bit more than a coincidence.
4) your injector deviation is a bit out of range
'06 Jetta DSG: Lifted, a few go not as slow goodies
'14 Ram 2500 Cummins
crazyrunner33 is offline   Reply With Quote
Old January 12th, 2020, 05:23   #35
crazyrunner33
Group 004. Your cam torsion is -3.4. That might be too far out(certainly is for my comfort). I'd plug your sensors back in and see if that's still the value. If it's still -3.4. I'd make tiny adjustments and advance the cam to around 0 to 1.0. Even if that's not the issue, the car will run much better once the issue is solved.
https://youtu.be/pAEmqvUpKEY
It's an easy adjustment to make.
Old January 12th, 2020, 05:48   #36
borjawil
I'll work on fixing the fuel filter lid and setting my timing. And clearing all the data and retesting for values. Let me know what you find when you get a chance to take a look. Appreciate it!
Old January 15th, 2020, 06:11   #37
borjawil
Ok so got the timing dead on at 0.0 the first try. So that's neat. My injectors are at -.9, +2.99, -1.4, and -2.3. Only the 2nd injector at 2.99 isn't fluctuation. The other move maybe .05.
Note the engine has only been running a few minutes. Wasn't sure whether to drive it to warm it up as there's the issue of it running poorly.
Only engine DTCs through auto scan are the glow plugs, EGR, and new one for a misfire on cyl 2. Which tells me that injector is bad as it's also not fluctuating like the others.
If I'm wrong let me know. Open to ideas on what to check next.
Old January 16th, 2020, 08:21   #38
crazyrunner33
Before assuming it's a bad injector, remove injection harness from the cylinder head and clean the connector. If that doesn't fix it, pull the valve cover and check the connections on the injector. You have known issues on the harness elsewhere, I'd rule that out 100 percent before replacing anything.
What's the actual DTC for the injector?
Here's a thread to refer to:
http://forums.tdiclub.com/showthread.php?t=245549
Old January 20th, 2020, 06:59   #39
borjawil
Don't remember the exact code. But I didn't get the electrical code as seen from your link, just the misfire code. Been freezing here and my car is an hr away, so I'll have to check my connections. Where is the injector harness connector located (not the individual injector connectors)?
Old January 22nd, 2020, 07:23   #40
crazyrunner33
There's a big round connector on the right side of the head near the tandem pump. No tools are needed to remove it, there's a tab to hit and it'll rotate off. If cleaning doesn't work, I'd pull the injector harness from under the valve cover and take it inside to test with a multimeter(check continuity and resistance). It's easy to remove the harness, there's two screws I think on the connector to the head, then unclip the connector to each injector and pull the harness out.
If the injector harness checks out, then it's likely an issue between the connector and the ECU, or the injector. You can inspect the cam while you have the valve cover off, never a bad thing to check on these cars.
Old January 22nd, 2020, 07:28   #41
borjawil
Thought that was the glow plug connector...it's been a couple years so maybe I'm mixed up. I'll check it out.
Old January 22nd, 2020, 07:54   #42
crazyrunner33
The glowplug harness ties into the main harness. Unfortunately, the only way to disconnect the glow plug harness is by cutting it and splicing in a new one.
Edit: Here's a video for the removal.
https://www.youtube.com/watch?v=FYcBahIzaOE
Old January 26th, 2020, 14:25   #43
borjawil
Checked injector wiring. Doesn't seem to be any issues. I did notice that the first time I read the group 013 for injectors, that the 2nd and 4th both read about 3.0. However the second time the 4th was 1.5. I read them again while wiggling the harness and connectors to see if anything fluctuated, which it did not. However this 3rd time reading them the 4th was back at 2.99-3.0 and after idling for about 5 or so mins began dropping to about 2.8, however I didn't wait to see where it would end up.
So I'm going to go ahead and swap the 2nd cyl injector with a used one. I have a few questions on this. I've read up on it, but want to check a few things.
1) what size and grade are the hold down bolts (the smaller ones more prone to stretching)
2) do I need to rotate the engine with the wheels off the ground when setting the lash?
3) do I need to replace the injector oring, and if so what size(s) do I need?
4) is there anything else I need to replace or check while that one injector is out?
Sent from my Pixel 3 XL using Tapatalk
Old January 27th, 2020, 08:45   #44
borjawil
Ok so after a bit of research I learned that the torsion value will read 0.0 and a p0304? (Implausible signal from cam sensor) will show if the timing is too far out. So adjusted and I'm at +1.0.
From 1-4 my injectors read -1.6, 2.99, .5, and -3.01.
However they change as I'm driving. The last cyl will go to -1.8. The 1 and 3 move as well. Though number 2 never does.
Old January 27th, 2020, 11:44   #45
borjawil
Re set the lash and 1 and 3 are under 1.0. 2 and 4 show the values climb until they stop at 2- 2.99 and 4-3.01
No longer have a misfire code for cylinder 2 either.
Read Frank's simplified lash setting. I also use a dial gauge. I wanted to clarify that the injectors/spring are compressed when performing lash. Cyl 1,2,3,4 from cam belt side or passenger side to driver side. 1 and 2 cyl have ex lobes on the left side of injector roller and 3 and 4 have ex lobe on right side of roller.
Vibration on acceleration turbo noise changed Electrodynamic VW MKIV-A4 TDIs (VE and PD) 0 February 3rd, 2017 14:36
No power on acceleration, stuttering, and smoke Spring1898 VW B5 Passat TDIs 4 December 18th, 2016 08:49
Hesitating stuttering on acceleration JamigTDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 March 30th, 2015 03:22
rough idle and stuttering on acceleration Gilly VW MKV-A5 Golf/Jettas 2 January 3rd, 2013 13:10
No Power, stuttering acceleration and smoke..97tdi speters VW MKIII-A3/B4 TDIs 4 July 5th, 2005 05:59
Page generated in 0.19644 seconds with 11 queries
[Output: 144.36 Kb. compressed to 123.49 Kb. by saving 20.87 Kb. (14.46%)]
