Old November 24th, 2008, 13:27   #1
TheGrove
Question Battery Replacement
I went to get my battery replaced this morning and we couldn't get the old one out. We got the bracket off that holds the battery down but we could not lift and tip the battery enough to get it out of where the tray is.
Is there a "trick" we were missing? The battery seems to get hung on a curved piece of plastic on the below the cowl/window. And there doesn't seem to be enough room to slide the battery forward to get more clearance. We saw a brace that ran all the way across the front of where the battery was (below the brake cylinder) that we thought if it could be removed would give us some more room but couldn't see how to get it out.
Fortunately the battery isn't shot but last winter if I left anything plugged in overnight it would sometimes crank very slow the next morning.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old November 24th, 2008, 13:55   #2
WYTDI
I just replaced my battery and had to remove the plastic cowl you mention. Both wiper arms need to be removed and the plastic can then be pulled up out of the groove that holds it in place. Start pulling the plastic from one side. This makes it pretty easy to lift the battery out. Also, be careful not to lose the rubber washers at the base of each wiper spindle.
WYTDI is offline   Reply With Quote
Old November 24th, 2008, 19:54   #3
afarfalla
afarfalla's Avatar
the cowl that has to be removed is held on by clips, if you start pulling, it will split, look underneath
afarfalla is offline   Reply With Quote
Old November 25th, 2008, 05:52   #4
EJS
TDI(s): 2009 Jetta
Confused - I see this thread & they didn't have to remove it????
http://www.passatworld.com/forums/sh...d.php?t=276780
Different battery? (same for me, will need replacing soon)
It's just my opinion & worth exactly what you paid for it.
EJS is offline   Reply With Quote
Old November 25th, 2008, 06:37   #5
TheGrove
Confused is right. We tried to slide the battery to the left and lift and it didn't seem to want to come out.
Thanks for all the replies we'll have another go later this week and see if we can't get it out.
Old November 25th, 2008, 06:54   #6
EJS
TDI(s): 2009 Jetta
I'd be interested in the results, I saw that thread & figured it was pretty easy......now it seems we have to remove another plastic piece?
Old November 27th, 2008, 09:02   #7
05TDI_Fan
Default How to make this battery fit?
Hello,
I noticed that the Interstate Battery MTP-91 appears as if it will not fit, as it is longer than the original battery. Does the clamp that holds the battery down move, so as to accomodate the larger battery?
I picked up the new battery and am waiting to install it.
Any advise?
Chris
05TDI_Fan is offline   Reply With Quote
Page generated in 0.11833 seconds with 10 queries
[Output: 73.70 Kb. compressed to 63.40 Kb. by saving 10.29 Kb. (13.97%)]
