Old February 15th, 2015, 08:57   #1
Victorjay
TDI(s): 03 VW Jetta
Default timing belt install problem crank moving
Hi all, I'm trying to get my new tb on and having problem with the crank moving. I have the ip pinned and the cam lock in but every time I thread the belt through and install the cam sprocket the flywheel moves two teeth back. Any ideas what I'm doing wrong?
Victorjay is offline   Reply With Quote
Old February 15th, 2015, 09:34   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
You need to lock the crank. You can use a special tool or even jamb a screwdriver (or other) in between the crank pulley and the block.
BobnOH is online now   Reply With Quote
Old February 15th, 2015, 09:39   #3
Bert0925
Fuel Economy: 50 MPG
Since you dont have a crank lock, some people wedge a screwdriver where the flywheel is to help it from moving a bit.
Once the belt is on even if it did move a bit, no worries, just move the crank by hand after to the mark. Provided the IP and cam sprocket are loose you can move just the crank and not disturb the other 2 since they are locked and its just the sprocket that is moving.
Just make sure that the IP ajustment bolts are somewhat in the middle.
Hope this helps.
Bert0925 is offline   Reply With Quote
Old February 15th, 2015, 09:41   #4
Victorjay
TDI(s): 03 VW Jetta
Thank you, I don't have the crank lock, tried te screwdriver but it moves. Can I loosen the bolts on the ip with the pin in, and correct the flywheel mark, one tooth off now...
Old February 15th, 2015, 09:42   #5
Victorjay
TDI(s): 03 VW Jetta
Berto, sounds like a plan
Old February 15th, 2015, 09:45   #6
Bert0925
yeh just make sure the cam sprocket is loose too
Old February 15th, 2015, 09:51   #7
Victorjay
TDI(s): 03 VW Jetta
OK looking good, that brought me back to tdc. going to tighten cam sprocket and rotate two turns,Thanks all!
Old February 15th, 2015, 10:15   #8
Victorjay
TDI(s): 03 VW Jetta
UPDATE, two turns and we're golden, all locks fit an tdc! Moving on 27 degrees in Baveria
Old February 15th, 2015, 17:38   #9
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Manual shift transmissions can be left in gear. The added load can keep the crank from rotating.
The cam and injection pump are pinned, but the SPROCKETS attached to the cam and pump should be loose (not more than finger tight). If the pump or cam sprockets are causing the crank to move, the sprocket(s) are too tight on the cam or pump shaft.
Svante Arrhenius 1896
Old February 16th, 2015, 12:34   #10
Victorjay
TDI(s): 03 VW Jetta
Ok, I think I should have had the pump bolts loose but didn't until I kept getting the crank movement, I did have it in R but still moved. I took the cam sprocket off to get the belt on so marking did no good. Everything is lined up still,looking good. Rear MM bolt broke today, stretched to much, went to dealer to get new one, didn't get to 44 lbs but not over stretched, other two good. Manifold install tomorrow after work & new GP harness install. Been down three weeks now, maybe rolling by this weekend. Thanks to all, I'll post pics when done...
timing belt, cam/crank timing, PD150 TIP NWVintage TDI Power Enhancements 7 May 28th, 2013 10:14
TIming belt break while moving, '98 TDi w/240K plus miles dyvyd TDI 101 26 December 17th, 2012 07:37
How do I hold crank to torque the crank timing belt sprocket? dslemaire VW MKIII-A3/B4 TDIs 6 July 18th, 2009 20:44
How do I hold crank to torque the crank timing belt sprocket? dslemaire VW MKIV-A4 TDIs (VE and PD) 1 July 17th, 2009 12:24
timing belt install problem compostbrain TDI 101 6 June 30th, 2008 11:16
Page generated in 0.15803 seconds with 11 queries
[Output: 92.11 Kb. compressed to 78.24 Kb. by saving 13.87 Kb. (15.06%)]
