Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old February 16th, 2009, 10:01   #1
Bengti
Fuel Economy: 50/45/40
Unhappy 92 Jetta 1.6TD starting problems.
I bought a 92 VW Jetta 1.6TD ~2 weeks ago and it has some starting problems. It doesn't start when the engine is cold. When the engine is warmed up it'll start just fine and it runs great once started. When cold it'll crank over but just not "catch". When cranking it'll smoke white smoke (oil i think). Just put a new set of glow plugs in, and they work. Changed the fuel filter.
The only way I can get it to start is to spray a little bit of starting fluid on the air filter (i know it's bad for the car). If you do this it takes a little bit of cranking and then starts to fire and if I give it a little gas it will turn over and run fine then.
To me it almost seems like the car is not getting any fuel when cranking it. Would this make sense? If anyone can help or has any suggestions please share.
Cars:
Former: 92 Jetta 1.6TD, 08 R32, 05 Jetta GLI, 67 Beetle, 02 Jetta TDI, 85 Jetta 1.6TD, 01 GTI 1.8T
Current: 99 Jetta TDI
Bengti is offline   Reply With Quote
Old February 16th, 2009, 10:12   #2
compu_85
Gadget Guy
compu_85's Avatar
You sure the glow plugs are working?
-Jason
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old February 16th, 2009, 10:16   #3
Bengti
My friend that changed them said yes. Both the old set and new that he put in he said he check, however i think I'll check them with a test light today when I get off work to be 100 percent.
Cars:
Old February 16th, 2009, 10:24   #4
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
Other than glow plugs, the only thing I can think of is a marginal battery. Maybe you should have it checked at your local auto parts store. Most will do it for free.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old February 16th, 2009, 10:28   #5
Bengti
The battery is dying. However when I try to start the car, it either off a jump from my truck or a battery charger.
Is there a temp sensor for the glow plugs on this model car that could go bad? Or maybe the relay?
Cars:
Old February 16th, 2009, 10:32   #6
Joe_Meehan
Joe_Meehan's Avatar
Frankly since you know the battery is dying, I would start right there. Jumping, with a marginal battery in the car being jumped often will fail. Few battery chargers have a high enough capacity to jump start a TDI unless they are heavy duty commercial models.
Joe Meehan
Old February 16th, 2009, 10:53   #7
Bengti
Let me rephrase my reply. The battery was fine but died due to me trying to start it and trouble shoot. The issue was there before when the battery was ok. A new one is on the list of things to get from the autoparts store anyway.
Cars:
Old February 16th, 2009, 11:21   #8
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
look under glow plugs in the search bar
it also could be a bad GP harness or an UNDERSIZED battery
what battery did you put into your car??
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old February 16th, 2009, 11:44   #9
Bengti
good idea bluesmoker. next step is to check the GP harness, relay, and fuse (fuse looks ok but will test light it)
I didn't put a new battery in the car yet. what should the Cold Cranking Amps be? Autozone says 650 or 700.
Cars:
Old February 16th, 2009, 12:55   #10
valvecrusher
valvecrusher's Avatar
TDI(s): '96 Passat
Fuel Economy: B4:∅, ECO:45+
Yes.
It's on the coolant line going into the head(right at the head). One is for the temp gauge, the other for the glowplugs.(both are black)
Try switching them to see if the temp gauge goes dead, but then the gp's work...
'92 Jetta GL ECOdiesel 1.6TD 1v K14
'96
Passat GLS TDI 1.9td AHU
'13 Passat TDI-SE 2.0td
die über das Angebot Angst vor schlechten Wolfsburg?
valvecrusher is offline   Reply With Quote
Old February 16th, 2009, 19:16   #11
bluesmoker
bluesmoker's Avatar
I don't want to start another battery war but I am partial to exide orbital extreme batteries, 1100 amps.
http://www.exide.com/products/automo...bital_XCD.html
http://www.exide.com/pdf/orbital_xcd...d_features.pdf
Old February 17th, 2009, 08:20   #12
Bengti
PROBLEM SOLVED!!!
Step 1. I went back and checked the glow plug system with a test light last night and found a problem, power going out of the relay but no power to the plugs. Checked the fuse and it looked fine, but I when taking it out for further inspection the one male end fell off in my hands. Also, after inspecting the wire connected to the fuse the wire was barely held on to the female connector and pretty much fell out. New fuse and recrimp connectors and i finally had power to the plugs.
Step 2. Since I now had power to the plugs I connected the car to my truck to jump (since the battery was DEAD) and it still wouldn't start. After trying and trying I left it on for ~10+ mins and it had just enough juice to fire when it was cranked. Took the car straight to the auto parts store and got a new battery.
Step 3. This morning it was 23 F outside when I left for work. Did a double cycle of the glow plugs just to make sure it wasn't too cold and she fired right up after about 3-4 cranks.
Thanks everyone who helped out with suggestions. I really appriciate it. I'm going to replace some of the wires/connectors since they are getting old and ratty but at least now I can drive her.
Side Note: When I got the car the fuel lines were full of what my guess is either biodiesel or WVO, or maybe old/gelled bio/WVO. It looked a lot like syrup only yellow and didn't really have a smell. Do you think that could have also lead to some of my starting problems?
Cars:
Page generated in 0.18160 seconds with 10 queries
[Output: 110.38 Kb. compressed to 92.89 Kb. by saving 17.49 Kb. (15.84%)]
