dbuzalski
Hello,
I need to change the pump on my 92 1.6td eco, and I know I should probably just go get the right one for it, but I have a good one from a 1.6td (non eco), the only difference that is obvious is the enrichemnt diaphram for 1.6td IP and the hp is higher on that motor than the eco so I'm sure there is something else different as well, but does anyone know if I can run it on the eco motor?
thanks
thanks
