So i feel a bit bummed out for a couple reasons.
1) that i haven't contributed anything to this forum and have only asked for help.
a) sorry, after i get this sorted, i'd love to help someone else accomplish a
similar goal.
2) that a motor swap, that should have been straight forward is not...
Ok. So with help, i solved my previous question. Thanks guys!
Now, brand new long block AHU in the westy. No start.
Heres what i've done:
- Checked timing 1308761490u times. every go is the same. Pin fits in pump, plate fits in camshaft, and flywheel mark lines up. Today i even went as far as dial gauging and Libbys vacuum trick to ensure #1 was TDC.
2- All air is out of IP. Used an outboard motor ball pump on the out flow side. Pulled fuel through the pump and had it squirt blah blah blah.
3- Checked Glow Plug circuit. Test Light OK for the plugs, in the 20sec, for the heating with coolant sensor unplugged.
4 - Moved IP throughout the range available for timing the pump. However i haven't yet got the gauge and measured plunger. As the pump was rebuilt, and on a strong working motor before, so i have no reason to believe its out.
5-changed batteries, Full charge each time.
6- Ran a Vag-com auto scan. First came with 6 faults. Cleared the codes, now i have none.
7- Ill post 2 pics and a video, let me know what you hear.
I'm kinda at a loss here, Anyone got any suggestions? Or lives locally that wouldn't mind taking a look with me?
similar goal.
