First post here, already been reading up as much as I can on doing a TDi swap for my 4Runner.
For starters:
My truck is a 1985 Toyota 4Runner. Originally equipped with the 22-RE 2.4l inline 4. W56 transmission and gear driven top shift t-case. Original ratio was 4.10 in the 3rds. As it sits now I have installed a 2" OME suspension lift, 10" Billstein 5100 shocks, 5.29's in the 3rds and a rear ARB locker with a Warn m8000 winch on the front. I'm running 255-85 r16 Interco Trxxus MT tires, which I absolutely love, especially in the snow! I've added a roof rack and some lights. I've built both F & R bumpers as well as sliders. The truck is pretty well setup to go where ever I want to... well mostly. Which is what brings me here. I have always liked the 22-RE. Super reliable and the only time it left me "stranded" was when the timing chain broke in front of my barn. And that was mostly my fault. However, as much as I love the little motor that could the limitations of it were always apparent. My house sits at 7,000ft here in CO. Which means just walking out my door and starting the truck up I'm already down 21% on power. The rebuild I did helped that and adding the 5.29's helped out a bunch as well but it still mean always slow and always 3rd gear revving it up the mtn passes. And since my truck isn't my DD usually when it would get driven we were headed to the mtns. I've always loved diesels, and for years I've toyed with the idea of putting a mercedes 617 into my truck. However the relatively low power output and weight of the engine kept me from pulling the trigger. Then recently I was speaking with a friend who also owns an 85 pickup and he was telling me about the VW swap. And well some more talking and further reading and well now the 22-RE is sold and I'll be picking up an '02 ALH here in a week or so.
Ok so now that I've rambled on for a bit let's start talking shop. As I mentioned I will be picking up an ALH from an '02 Jetta within a week or two. Killer part about this is the guy is parting out a wrecked car and is willing to give me everything I need for one very reasonable price. So In order to take him up on this offer I need to have everything listed out of what I need. So what I know I need:
Motor, ECU, OBD port, Cluster, Ignition. Some reading also suggests there are some relays I need, as well as clutch and brake switches.
Breaking it down motor with ECU obviously along with associated wiring harness. Any special concerns here?
OBD port shouldn't be any prob to have and will enjoy having the diagnostic capability.
Cluster, how important is this considering I am planning on integrating all functionality into my stock toyota dash?
Ignition, as I understand this is important due to the immobilizer. Eventually I plan on deleting the immobilizer is there any need for the ign past this? Any recommendations on where to send the ECU to have the immobilizer disabled?
I've seen mention of some relays but haven't found any specifics yet. Which ones will be most important to grab?
Clutch and brake safety switches, how difficult will these be to bypass? I don't have either now and really don't want either.
Last thing I know I need is the accelerator pedal. Any further input would be greatly appreciated.
Some other quick questions, I know this post is getting pretty long,
Who has used ACME adapters to mate their TDi to another transmission? How was the fit and finish?
What are some of the common failures on these motors? Anything to address when the motor is outside of the truck?
I've heard that tuning these motors can yield some good power numbers how realistic is it to get 200hp/350ft/lb?
Thanks in advance!
For starters:
Thanks in advance!
