willafb
Anyone have a flashing glow-plug appear? Mine keeps appearing when its 30f or colder, dealership has had it for 4-days.
Good luck and let us know wht they say. I'm surprised you don't know exactly what is wrong if they've had it this long. Call them, ask, they should tell you something more than "still looking".Anyone have a flashing glow-plug appear? Mine keeps appearing when its 30f or colder, dealership has had it for 4-days.
Should be covered....Usually blinks because the ecu is injecting too much fuel. Probably a faulty fuel temp sender, which Is inside the HP fuel pump.
If you've heard of the evry mod, it uses the same principle. tricks the ecu into dumping more fuel by sending a faulty fuel temp signal. As soon as the ecu detects the fuel flow, it triggers the same blinking glowplug light.
Id say they probibly pulled the HP fuel pump off to replace the sender, which takes time and, get ready, $$$$$$$
