I've read thru all of this install post. I have tools I need on hand. I'm considering buying AA Rodriges steering knuckle unit replacements for MK4 (2003 Jetta). Please no posts on just do the bearings. Not going that route.
Once I remove the knuckle from axle and front strut, then reattach the new knuckle, how does one get it to go on the axle? Maybe dumb question, did not see any pics.
Do you have to press it on reverse of using hub puller to remove it from axle, or just get it started on splines (after lightly greasing the splines) and then as you tighten up the nut, does that tighten the hub/new knuckle onto the axle spline?
Never done this before, have done many things with great help from people on this forum, so looking for clarification.
I do have blurry vision, so it takes me longer. Taking it to a shop is no in my budget at this time. And yes, I've verified using jack stands that the drivers side is indeed bad.
thanks coulee
Carefully working with the cut off wheel on my Dremel I was able to save both wheel sensors. $70 for two at idparts....it was worth it to save them.You should do an alignment after that too. There are special tools for that as well.
Oh, and you may need to replace the wheel speed/abs sensors. They are plastic, fit in the knuckles, and often break when being removed. Getting new ones for the new knuckles is easier.
I think that that's the one that I have (would have to look). I couldn't get the hooks under the race lip! I ended up dremeling groves further up and getting the hooks to catch; this was a last ditch effort, and I really struggled to get it to work (a rubber band would likely have helped, though not sure how much- it was more about the hooks biting into the metal). Next time I go to do this I'll be sure to have a better plan/tool!I had a two-jaw puller kit already in my tool arsenal and gave that a try the second time I had to do a wheel bearing.
I've used it a few times now and while it takes me more time to assemble the puller than to actually pull the inner race off, I smile every time I use it because it's just so slick.
I've got to check that out! I'm going to run out to my car and pull... For sure, the next time I go to do this, which I hope isn't for a LONG time, I'll know what to look for to make this work much easier than it was for my first R&R.Just did a bearing replacement today, and noticed that a few positions around the inner race where I couldn't get the jaws of my puller to stay square.
Having said that, there was at least one where it wedged in nicely.
This has been my experience as well. No amount of futzing with the puller would get it to grip but 30 seconds with the Dremel and a few whacks of the cold chisel with a mini sledge and the inner race popped right off.I fought with a puller last night for about an hour and simply couldn't get enough bite to pull the race off. Went in the garage and busted out the dremel and with a cut-off disc I cut a notch down the race in about 5 minutes and took a chisel to and and after only a couple whacks it cleanly slipped right off.
I cut it at an angle and didn't even come close to gouging the hub. Just take it slow and you shouldn't have any issues. Don't worry about trying to cut through it completely. If you get 90% through it, you can crack it with a chisel.You all that are dremeling the race, how did you get the lower "mushroom" part of the race cut? If I recall correctly, I wasn't able to cut down there without gouging into the hub itself: running parallel to the hub's shaft it's hard to get a round wheel to cut to the base.
Well, I'm glad that one of has the right tool!Given what inadvertent damage I've done with a Dremel before, I'm happy to stick with my puller. A couple minutes to put it together and then hit it with the impact gun - done.
(And gives me a very self-satisfied smile when something works that cleanly and easily.)
Before coming across this post, I faced the problem. Before taking the dremel out, I took the assembly to a local shop asking if they have a puller. Helpful experienced mechanic: "no tool, but I can take it off for you in a minute".But you still have to contend with the OTHER part of that damned bearing - the outboard inner race that's still stuck on the hub.
I had to cut all the way through mine to get it to budge. Cutting the race off is much easier and faster.
I would try to gently straighten it out, but it should be OK to use. The Bentley says the tone ring should be 0.3mm from the wheel speed sensor so use your best judgement.Hey guys, I bought a used spindle/knuckle from a guy locally and it turns out that the hub ABS ring has a slight bend in it.
Would it be still fine to use?
My personal opinion is no amount of grappling will remove the hub better than a slide hammer, but your grappling skills could be better than mine. Have a buddy make a video of it, YouTube it and let's find out! This definitely sounds like a "hold my beer and check this **** out" kind of moment.when I get to the point of getting the hub off if I put the wheel back on tighten the bolts, if I grapple with it do you think the hub will depart the housing im thinking it will.
Maybe a little wobble is normal. The inner race is in two pieces, and tightening the axle nut squeezes them together to put some pre-load on the bearings. (It would probably be more correct to say there are two inner races.)Once the hub is installed, will it be a little wobbly before getting the axle torqued down? It turns fine but has some play in it.
I used an electric. No problem at all. However, it was a Milwaukee 2763-22...Has anybody used an electric impact gun to remove the wheel bearings with the wheel bearing tool?
I don't have air tools but I do have an electric impact gun that's pretty much brand new.
