BuzzWagon
I have a 96 tdi station wagon that I drive the wheels off of, and a little while ago the drivers side headlight went out. I put an new bulb in it and it does not work either. I also switched the working bulb out of the Passenger side and it will not light up, so I know the bulb is good. Now here is the strange part, my driver side High beams work just fine...
I then got pulled over with the drivers side tail light out (only a warning when he saw my ccw permit ) however it has the same issue. No light with a good bulb. And the Break light and turn signals all work just fine.
I have checked over the wiring harnesses that are accessible and they look fine. My next thought would be the main light switch as I know they can be picky...
Any suggestions?
Thanks!
Any suggestions?
Thanks!
