Dan_Powell
I have read on the many MAF threads here that once you re-connect your MAF, the CEL should go off after a few key cycles. Is that true? I replaced my MAF last week and after about 20 key cycles, the CEL still comes on and the MAF code is still there. Do I need to clear it, or should it go off soon? If I had VAG-COM, I wouldn't need to ask this question.
