wolfie1953
Well, finally got around to adding an aux fuel tank to the 2015 Golf TDI. Never was happy with the size of the tank (13 gal.) and the range. The goal was to make a system that did not require a pump to move the fuel.
All AL tank was made by a local fabricator for $480 and another $400 for labor and parts to install. Would have done it myself, but needed a lift to get under the car.
The fill pipe is thick plastic, strong and presents many options for splicing in the tank fill pipe. Since the trunk is higher than the installed fuel tank, gravity does the work, and no pump is needed.
A kit could be made to do this worthwhile mod.
New at this, can't seem to paste any pictures.
(Would someone please explain how to add pictures. Thanks)
