- Joined
- Jul 2, 2000
- Location
- Springfield, VA
- TDI
- ‘18 Tesla Model 3D+, ‘14 Cadillac ELR, ‘13 Fiat 500e
Adding a poll option at this stage in the game will not produce useful results.
I respectfully disagree. Ice forms in there when the condensing water meets cold temperatures. The ice itself does not cause a bad startup....it doesn't go through the system. The IC is often cold enough for ice to form in cold climates. It gets way colder than 32F.Get the word ICE out of your head for a moment. It's condensation and a lack of heat. If it is 32F(and even colder, though how much I can't say) it is impossible to create ice. The IC is always going to be the same or hotter than ambient air. You're collecting water. Most cases, IMO, there is no ice until you let it sit out in subfreezing weather, after the water has condensed and accumulated.
Can you post up some pictures for everyone?I just wish to report I have the original IC, going into 4th winter, thousands of miles in ideal IC freeze-over conditions, 3-5 hard start situations in all this time, and I don't have any issues when I have the bottom 3 intake slats blocked with simple foam pipe insulation tubes.
Same thing happened to me. They wouldn't do anything until it hydrolocked and I had it towed in (814 km tow!). I sent them the info about he TSB's in this thread. They also told me that there wasn't one for the 2014, but they did put in a different intercooler some kind of vacuum actuated thing near the throttle valve after consulting with the VW tech line or whatever they call it.Count me in as a likely new member of the icing club...had my car run like crap yesterday with the sudden warm-up in Southwestern Ontario. Got to the bottom of my driveway and as I went to pull away, she stalled out. With someone now bearing down on me, I cranked her over and it started, stumbled and stalled again. Fortunately the clown who was bearing down on me finally noticed my 4-ways and slowed down.
I cranked it again (no hydrolock) and she fired up, and ran like hell for about 45 seconds with little power. Then it cleared up and ran reasonably fine (probably me being over-sensitive).
Called the dealer today to report it and schedule in my 20,000km service, and was told that my 2014 should have come from the factory with the new intercooler. They said there is no bulletin on 2014's. True? I'll add to the poll when I know which intercooler is on my car.
They're still going to look at it and also apply the block-heater recall. Le sigh....
