This is what can happen to your tires on the pot hole strewn streets of Montreal
Good thing I did not bend the rim, so, I had a set of these installed today as well as had an alignment, which was knocked way off on front drivers. Needless to say next time I have to go to Montreal, I'll take the Truck
Never heard of alignment being a cause of gashed tires.A pothole didn't do that, your alignment has been out for quite a while.
Hit the pothole with the drivers side front, did not know it cut the tire. When I did the alignment, the drivers side front was actually within spec at:Never heard of alignment being a cause of gashed tires.
Ahh - that was the missing bit of information where I made a wrong conclusion.............
So, that tire was not out of alignment. After hitting the pothole the tire started to swell at the cut and developed a bubble. Past the point of the cut on the picture, the tread is still present and uniform with the rest of the tire.
MrVermin
Could be that you were a bit under inflated since the ware is on the outside of the tires but the center still has lots of meat left. Unless you like taking turns at high speedsHit the pothole with the drivers side front, did not know it cut the tire. When I did the alignment, the drivers side front was actually within spec at:
Before Alignment specs:
Left Front
Camber: -0.7
Caster: 7.4
Toe: 0.05
Right Front
Camber: -1.0
Caster: 6.9
Toe: 0.01
After Alignment specs:
Left Front
Camber: -0.8
Caster: 7.4
Toe: 0.02
Right Front
Camber: -0.8
Caster: 7.2
Toe: 0.01
MrVermin
Drove from Toronto to Montreal (Location of the pothole), checked the tire pressure at the last "En-Route" station on highway 401 before crossing into Quebec from Ontario, all at proper pressure (well maybe a little higher ).Could be that you were a bit under inflated since the ware is on the outside of the tires but the center still has lots of meat left. Unless you like taking turns at high speeds
Ahhh, makes sense nowDrove from Toronto to Montreal (Location of the pothole), checked the tire pressure at the last "En-Route" station on highway 401 before crossing into Quebec from Ontario, all at proper pressure (well maybe a little higher ).
Only tire that had this issue was the front drivers side and that was after the encounter with the pothole and the only place where the tread was damaged was at the point of the tear in the tire. The tear broke some of the cords under the tread, then the tire bubbled at that point causing the wear at that spot. The rest of the tread on that tire was uniform across the tire before and after that tear spot.
MrVermin
What piece are you talking about? BTW, I wish people would post a picture or link when they make similar posts as not everyone has the entire VAG parts catalog for the last 20-30 years memorized.Finally broke down and got one of those plastic trunk fixes for the Jetta after repairing the broken piece 3 times. Hope it holds up, got the one that sits on top and is held on by 3M adhesive.
Pricey little plastic piece especially shipped to Canada.
This little piece:http://www.ebay.ca/itm/VW-Jetta-Trunk-Latch-Plastic-Volkswagen-Trunk-Fix-Trunk-Arm-Latch-1999-5-2005-5-/121112092765?hash=item1c32d7e05d&vxp=mtrWhat piece are you talking about? BTW, I wish people would post a picture or link when they make similar posts as not everyone has the entire VAG parts catalog for the last 20-30 years memorized.
Thanks. As for the worry part, now I may have to worry about what MIGHT go wrong with mine!This little piece:http://www.ebay.ca/itm/VW-Jetta-Tru...5-5-/121112092765?hash=item1c32d7e05d&vxp=mtr
You won't have to worry about it, I think the wagon uses a different mechanism.
You do realize that the way you wrote the sentence means the WAGON gets the HOUSE?Bought a 26 by 26 shop with a house for the old wagon
unfortunate nickname for your wife.Bought a 26 by 26 shop with a house for the old wagon
