Since clogged cores has angered alot of us, and since alot of us have scored a stop sale with essentially zero miles, AND alot of us are planning to ride out the warranty period....
Should one take it upon themselves and flush the coolant 2 or 3x before 100k? Seems petty pennies for the headaches of a clogged core when out of warranty...
I think we've come to the conclusion the extensive heat with the water cooled egr/dpf combo has been the culprit of coolant issues.
Those who plan to delete only after riding out the warranty, I'm curious if increased intervals of of fresh coolant flushing might possibly limit the possibilities of headaches down the road?
Granted you can replace a heater core, but what other areas are getting clogged or reduced efficiency, on top if the labor of anything can be reduced or eliminated with a simple hose clamp removal.
Sent from my 2PS64 using Tapatalk
