mangus580
I am having some issues with the 09A in one of my 2005 wagons.
The issue is intermittent. Comes and goes on a whim... cant seem to predict when it will do it and when not. Once the problem is there, it tends to hang out for a while, and when it goes away... it stays gone for a while. (while could be 60+ miles of driving with or without stops/shutoffs in the middle)
When it exists, I have the following issues:
Starting from a stopsign/light, letting off the brake, it will creep forward like normal. when you try to give it some throttle, it acts like its not in gear... tries to engage, and doesnt, until it generally 'slams' (severity depends on how hard you are trying to get it to engage) into gear, and takes off. goes fine from that point.
Also - it will have a flare on the 3-4 shift.
It seems... I can mitigate the take off issue, if I manually downshift through the gears all the way to first as I come to a stop. On the way down, the 3-2 shift is delayed and hard. As long as I downshift like this, I have a 90% or better chance it will come off the stop with no issues. But... the 3-4 flare is still there.
Sometimes... the car will drive for miles (have driven almost 100 straight) with no issues. Totally normal - not a care in the world.
Some minor background.... not long after I got it (roughly 120k or so miles on it at this point) I had issues with reverse engaging... so I had the 'reverse lockout' solenoid replaced in it.
Last fall (roughly 170k? miles) I had to replace the 1-2 solenoid.... so i decided to have them all done. I bought them from vwpartsfl on ebay....
This spring... I had an issue, where it started going into limp mode.... one of the 'new' solenoids failed on me. Caused all sorts of grief... and finally got it replaced by my mechanic from a source of his own.
What I am thinking now is... I have another bad solenoid. Car has 205k miles on it. when it wants to, it drives as nice as can be. just like my previous solenoid failures. they had a mind of their own.
It has been suggested a bad valve body... but honestly, with the one bad solenoid from the new pack, I am hesitant to agree. Especially since its such an intermittent issue. I would think a valve body would just be a constant headache at this point, and I wouldnt have any normal driving at all anymore.
I am looking for opinions... I cant afford a valve body at this point. Truth be told, i cant really even afford to have a solenoid replaced at the moment. But, since this is the car i drive for work... i really need to figure out something, so it can be a bit more reliable.
I am almost wondering if it could be the N92 solenoid, as that is supposed to be on for 1 and 4 to engage (5 too... but by then its already on from 4?)
If I have to replace them all again to be sure, so be it... but quite frankly, this is getting a bit old!
My other jetta has 250k on it, without a single issue in the same transmission!
thanks for any help,
Mike
Mike
