Hammy
How does the '03 Golf transmit the vehicle speed signal (VSS)? I assume that there is some communication of vehicle speed to the radio for the speed-adjusting volume. Is this signal transmitted by hardwire, or some other method (some sort of networked CAN communication)? Can we use VAG-COM to find out the signal frequency?
I am trying to retrofit a Ford Nav radio to my Golf and I need the VSS hooked in. Otherwise, I have to run off of GPS only, which lowers the accuracy and slows the system down.
